i need a baseline map for the vortech splitsecond box ASAP!
Old Sep 12, 2005 | 11:10 AM
googe's Avatar
so i ordered and installed my vortech supercharger kit and drove up to my mechanic to get a tune and apparently i got shipped a splitsecond with completely blank maps. does anyone have a baseline map they can send me by any chance?
im out of town at the shop and here we are with our thumbs up our asses until we can get a map
Old Sep 12, 2005 | 11:40 AM
booger's Avatar
Ok...did you connect to the ECU ? Did you read the ECU ?
Old Sep 12, 2005 | 11:41 AM
booger's Avatar
Did you boost it at all since the install ? If so did the A/F drop below 14.7 to 1 ?
Old Sep 12, 2005 | 11:44 AM
booger's Avatar
The reasons for the Questions...is if you didnt read the ECU , its not going to show anything .
googe's Avatar
yeah ive been driving around with it for a week (approx 500 miles) on the stock tune. i havent had a wideband on it yet, we just connected to the ecu and the connection went ok, but the tables all had 0 values.
we may have got a hold of a baseline g35 map from someone it looks like, but if you happen to have a factory vortech file that would be really handy its an 03 btw.
Old Sep 12, 2005 | 11:46 AM
googe's Avatar
er, kind of confused. read the ecu, or the split second box? we didnt touch the ecu.
Old Sep 12, 2005 | 11:49 AM
booger's Avatar
There is a base map in the Split second piggyback .Connect to the piggyback with the lap top . Up in the top left hand corner..there are two boxes . When you put the mouse on them ...one says write to ECU and the other says read the ECU . Click on the one that says read the ECU...that will load the MAPS to your laptop
Old Sep 12, 2005 | 11:54 AM
googe's Avatar
right, we did that...actually i didnt see him click the "read ecu" button but i pointed it out and he reassured me several times that he did that and thats how we got the tables full of 0s.
but vortech just sent us a stock map and we got it loaded so were up and running...
thanks for the help anyway
booger's Avatar
Open the R4 program.....you will have select a com port...then connect to the Spit Second ECU .
Even a better idea is to go to Split Second web site and down load or read the file...U-TUNE....this will tell you how to up load and save the base map that is already in the SS box . www.splitsec.com
Old Sep 12, 2005 | 11:55 AM
booger's Avatar
COOOOOL.....good luck
Old Sep 13, 2005 | 04:57 AM
googe's Avatar
well we ended up making 300whp on a mustang dyno. he wouldnt do the timing because vortech said to leave it alone.
i dunno, seems a bit low?
Old Sep 13, 2005 | 08:18 AM
neffster's Avatar
Googe, I have a few dumb questions...
Do you have a dynojet near by?
What was your boost at when you hit 300rwhp?
Can you get your belt any tighter?
Did you have the stock wheels on?
Old Sep 13, 2005 | 08:58 AM
booger's Avatar
with out touching the timing thats pretty good . With the 3.12 pulley and A/F tuned ...timing set to 14 to 15 degree BTDC at redline . I made 350whp on a Mustang dyno, thats on a AT5 03 G35 . I figured I was right on par with the guys making 390 to 410 whp on a DynoJet . Track times and trap speeds were all close to one another also
Old Sep 13, 2005 | 01:51 PM
googe's Avatar
neffster:
yes, the shop charges $75 for 2 pulls...i was thinking of heading over there just to compare numbers but im not sure that its worth paying for
it was around 5.8 psi i believe. the dyno was 3000ft above sea level, which is about a 1.5 psi difference. so effectively 7 and a half psi or so?
nope, it was JUST tightened prior to tuning and going on the dyno. shes tight!
yes, stock 03 18" wheels
Old Sep 13, 2005 | 01:54 PM
googe's Avatar
it sounds like there is a lot left in it if you play with timing. i was kind of disappointed that he didnt actually. when he called vortech for a map, the guy he spoke to said he wouldnt advise doing the timing, so he refused are there known issues doing timing on this car? i havent noticed anyone on the forums saying anything about that.
