How different does a turboed engine sound from stock NA?
Old Oct 2, 2005 | 01:41 PM
haze's Avatar
As titled, response much appreciated.
thanks
Old Oct 2, 2005 | 02:58 PM
Repsol's Avatar
I think the only real difference is hearing the turbo's spool up and then hearing the BOV. Other than that, you can't really tell. At Idle, it should sound the same for the most part.
Old Oct 2, 2005 | 07:58 PM
djniknala's Avatar
Mine sounds quieter than an NA car with my same exhaust and it stays alittle quieter during full throttle. You can really hear the turbos when they spool up especially at 14+psi.
Old Oct 2, 2005 | 09:35 PM
haze's Avatar
are all types of BOV audiable? Are there any "stealth" BOV?
Old Oct 2, 2005 | 09:59 PM
caelric's Avatar
Turbo'ed cars are generally quieter than equivalent non-turbo cars. The turbochargers act somewhat like mufflers by cutting out the exhaust sound.
As an example, I, for a very short time, ran my Z32TT with straight pipes (no cats and no mufflers) and it was still tolerable. Try that with a non-turbo car and you will blow your eardrums (figureatively)
However, with a turbo'ed car, you will hear the turbos spooling up, and if you have a BOV, you will hear that every time you let off the gas after being in boost. All things being equal, though, a turbo'ed car is more quiet than a non turbo car.
Dave
Old Oct 7, 2005 | 07:58 PM
haze's Avatar
so a BOV is not a requirement for a turbo setup? And I assume there are BOV will different "volume" of sound too?
Old Oct 7, 2005 | 08:34 PM
hyperlitesmu's Avatar
2 Cars......2 Turbos...
If you are going for a stealth look and still want the ability to release the compressor side pressure from your system some sort of bypass or BOV is necessary. It prevents compressor surge and can either be really loud and audible or damn near non existent. A recirculated BOV back into the system cuts down on sound dramatically, additionally using a bypass valve instead of a BOV will all but eliminate all sound made by the pressure release of the turbos. Think of a bypass valve like something on a stock turbocharged vehicle....you can't hear those turbos when you shift....same principal only applied to an aftermarket turbo system.
A turbo system itself will make you NA engine quieter throughout the RPM band. The very nature of running your exhaust gases through more piping (turbo exhaust housings) will reduce the volume of the exhaust. Certainly a lot depends on the exhaust set up you have, but regardlees the note should be quieter under all driving conditions.
Old Oct 7, 2005 | 10:31 PM
paranormal's Avatar
i have no cats and at WOT MY **** SCREAMS
Old Oct 7, 2005 | 10:41 PM
JDM 350GT's Avatar
think the BOV is the only thing that tells you the dif.
Old Oct 7, 2005 | 11:42 PM
caelric's Avatar
Well, thats why. If you also had no turbos, it would be even louder. The turbos (as I said earlier) quiet it down some, kind of like mufflers, but don't make it silent.
Dave
Old Oct 8, 2005 | 12:18 AM
Orlando333's Avatar
it is quieter; sounds like a choochoo train, until the BOV goes off
Old Oct 8, 2005 | 10:21 AM
haze's Avatar
thanks for the responses guys.
Old Oct 8, 2005 | 10:52 AM
Pwoz's Avatar
They turbos will make a whining noise too, it's farily subtle on all the cars I've heard though.
Old Oct 8, 2005 | 12:22 PM
tony's Avatar
I had test pipes n/a and now have them turbo.. the car was loud as hell n/a, much quieter now but it still sounds mean at WOT.. I love it.
jsimonk
Dec 22, 2023 03:49 PM
TWASkyliner
Feb 8, 2020 08:00 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
ghost_g35
Aug 7, 2015 10:31 AM
