X FI Options?
Old Feb 19, 2006 | 10:59 AM
DP03's Avatar
X FI Options?
Ok guys, I've been looking around this forum, and so far the only FI option for the X that I've come accross is the Stillen SC. Is this correct? Looking for some alternatives....Thanks.
Old Feb 19, 2006 | 11:15 AM
Xman's Avatar
I have a Vortech. You also might be able to fit a ST in there.
Old Feb 19, 2006 | 05:26 PM
powerhousefan's Avatar
you can fit just about anything but tuning will be a problem. your best bet is to stay low on boost
Old Feb 19, 2006 | 05:55 PM
DP03's Avatar
Do you mean tuning to be a problem on the G's in general or for the X? What would make the tuning on the X any harder?
What setup are you running?
Old Feb 20, 2006 | 03:16 PM
just the x version because it only comes in auto. it's very hard to dyno/tune awd auto vehicles. i have a stillen s/c stage 2.
i know xman has some kind of tuning solution on his car. talk to him if you plan to go a different route.
Old Feb 20, 2006 | 03:26 PM
QuadCam's Avatar
nitrous would be sick with the X's AWD system!!!
I would launch so much harder than any other FI setup out there.
I used to have a nitrous setup on a V8 AWD Explorer. It was awesome. that big heavy truck pulled 1.8 and 1.9 60 foot times at the track
Old Feb 21, 2006 | 08:37 AM
DP03's Avatar
Well, someone knows how to tune AWD AT, cause I've seen plenty at the track.
At any rate, can someone explain to me why the Stillen setup requires no tuning? At least that's what I've read in this forum. I know it uses the twin screw design, but I'm wondering how that eliminates the need for tuning. Is it because it isn't making the hp levels of the others?
Old Feb 21, 2006 | 08:00 PM
Xman's Avatar
The Stillen Stage 2 uses an extra injector to deliver the needed fuel under boost. As I understand it has a stand alone system that electronically regulates timing and A/F. Probably finds a happy medium for all VQ applications.
Old Feb 23, 2006 | 02:13 PM
superchargedg's Avatar
the stillen cant be tuned beyond the fmu,but if you really want to tune it without the stillen fmu,give mike at aam a call,they get rid of the 7th inj,install new injectors,fuel pump,utech(replaces stillen fmu),af meter etc.
Old Apr 4, 2006 | 03:11 AM
nate4598's Avatar
how much $$ would this cost and what's the estimate hp gain would we be seeing (assuming that 8psi & on the safe side)?
Old Apr 4, 2006 | 10:49 AM
mike at aam quoted me about $3500,to me it wasnt worth it,im putting on the stage 3 pulley soon,then going stage 4 and thats it.
Old Apr 4, 2006 | 11:32 AM
nate4598's Avatar
$3500 might as well going stage 4
prinny
Nov 22, 2015 11:07 PM
ncg35guy
Sep 24, 2015 04:53 PM
Moskvitch
Sep 14, 2015 10:15 AM
