G37X on the way, Article attached
Infiniti looks to add the g37 All Wheel Drive!
http://www.egmcartech.com/2007/08/31...l-wheel-drive/
Well here is another article to add http://www.edmunds.com/insideline/do...ticleId=122416
More press on this rumor:
http://www.leftlanenews.com/infiniti...g37-coupe.html
Good idea, but she'll be a near-4000lb porker!
I really hope they add another 25HP to the X version, to offset the "fata$$ness"
Originally Posted by chilibowl
Thats alot of meat! More cushion for the pushin !!
You can't add HP to compensate added weight. Sure, it might be true for acceleration, but handling would take a hit. Which means the ride would have to be stiffer in order to compensate for the added weight if handling were to be equal to the S; which therefore, causes a less desirable ride.
If anything, Nissan needs to find a way NOT add anymore weight to the AWD. It might add a little more to the price tag for weight saving, but I think its a must.
I would rather have a G37 with 306 HP @ 3300 lbs than a G37 with 330 hp @ 3700 lbs.
I also wouldn't mind Infiniti making a G coupe with a shorter wheelbase than the sedan while reducing overall length as well. Something more compact with tighter dimensions would be better. The G37 is more like a male lion that has overstuffed itself on antelope rather than being a lithe leopard, ready to pounce.
More ponys and less fat.........!
I was supprised when Nissan put out the Nismo Z and didn't offer the 330 HP
version. I saw one on the street and didn't think the body kit looked good,
gererally everything looks better in black......NOT! Nissan wake up and listen
to what your public wants!
