The FX-Spot For General discussion of the FX35/FX45
Running wires
Old Apr 2, 2021 | 07:30 PM
Tim Wilson's Avatar
FX35
Running wires
I’m looking to run a new ground wire from my crankshaft sensor to my battery. Does anyone know an easy way to run that ground? Not sure how to get from the sensor/bell housing area to the battery area.. Any advice would be helpful
Old Apr 2, 2021 | 08:34 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Replied to your pm. I'll try to see if I have any pics, I just had my tranny out a couple weekends ago and was taking pics of other things.
Old Apr 2, 2021 | 08:55 PM
cleric670's Avatar
BANNED!!!
Here's a bunch of random pics I found, personally I think you're PROBABLY best off with zip tying onto that harness right next to the CKP and going forward under the headers on the driver side, I don't know exactly what that harness leads to but it goes up at some point. Remove the engine bay lower plastic cover and there will probably be some big obvious place to go up. If not then on the passenger side on the battery box there are a couple of fuel or evap lines that run right down near the starter, if you can jump over to the starter somehow then you definitely have a way up.
soundmike
Sep 21, 2012 01:45 PM
tibasnatch
Mar 10, 2011 11:52 PM
gh0st
Jun 18, 2010 03:50 PM
KPierson
Jul 30, 2006 11:45 AM
99atlantic
Jan 14, 2006 09:17 PM
