G35 & G37, Coupes & Sedans
***update on my MAZDA flip key FOB mod. alternative to nissan key fob.
Old Apr 23, 2007 | 08:01 PM
  #136
accordfreak's Avatar
need pictures
Old Apr 23, 2007 | 10:35 PM
  #137
oscottio's Avatar
Originally Posted by sameernof
It might be better not to use tissue paper, but instead use something that is not easily flamable in case u accidently short the circuit, like alluminum foil, or rubber/metalic washers. Just IMHO.
ok, i'm not an electrical engineer, but common sense tells me that aluminum foil or metalic washers will do more harm on a bare circuit board then tissue paper...IMHO
Old Apr 24, 2007 | 03:35 AM
  #138
RST531's Avatar
use electrical tape
Old Apr 24, 2007 | 04:54 PM
  #139
RocketG35's Avatar
Why do I bother to DIY???
I had trouble with my case closing too...so I needed to dremel the case more and more. I accidentally burned a hole inside the case...minor thing, but it's not water resistent anymore.
Even now, when I remove the case to make adjustments, it is difficult to line everything up perfectly. Sometimes the buttons aren't sitting right and then the buttons are already depressed. But once you have it set right, no problems...my range seemed to have improved for some reason lately.
Old Apr 24, 2007 | 04:56 PM
  #140
RocketG35's Avatar
By the way...here was my thread on this mod:
https://g35driver.com/forums/g35-sedan-v35-2003-06/141266-10-hours-work-not-sure-if-worth.html
Old Aug 24, 2007 | 11:16 PM
  #141
6-Pack's Avatar
I took my key apart, took out the chip, took the key blade and chip to the car...and cant get the car started. am I missing something?
Old Aug 25, 2007 | 09:03 PM
  #142
6-Pack's Avatar
when i test the wires, they work fine..then i solder on the buttons and nothin...what to do?????? if these buttons are busted can i get buttons from somewhere else?
Old Aug 26, 2007 | 02:56 AM
  #143
RocketG35's Avatar
Not sure how close the chip needs to be to the key in order to bypass the immobilizer. I had that happen as well when i did a quick test. However, once i dropped it in the mazda case, it worked fine.
Re: the buttons...did you solder a wire to each end of the button....diagonally? Do the buttons click when you push down? I melted one during an attempt and the button would not click down. Also, if different buttons's wires touch one another, then it may not work.
I also wondered where I could get additional buttons - no one here could tell me where.
Old Aug 26, 2007 | 10:27 AM
  #144
6-Pack's Avatar
hmm..thanks for the tip on the chip. i think the buttons are ok..they all click, and i soldered them on diagonal prongs. is there some special way they need to go on? i soldered the wire onto the metal lookin thing on the underside of the button.
Old Aug 26, 2007 | 10:33 AM
  #145
6-Pack's Avatar
digikey probably sells them...but dunno what part to look for, and there's no pictures
Old Aug 27, 2007 | 08:16 PM
  #146
JDM_SKY's Avatar
Did anyone try to mod the OLD fob into the new G35 FOB?
we can simply just swap the parts?
Old Aug 28, 2007 | 01:22 AM
  #147
filanj's Avatar
lilsnoozer is currently doing my mazda key for me. Very nice guy and very business appealing.
Old Aug 29, 2007 | 11:34 PM
  #148
how's the range on yours. I never got around to fixing it. Mine still works within 10 feet or so though..
Old Sep 20, 2007 | 03:05 AM
  #149
RocketG35's Avatar
mine is still spotty - I've retired it for now and am using my other key fob. I need to take it apart and try to improve it...one day I'll do it.
Do you get 10ft all around? Or certain angles? Depending upon the angle I can get some distance...I think the farthest I've ever got was maybe 30ft. Two places: 1) rear of my car, driver's side, about a foot to the left of the car, 25 ft back; 2) front of car, driver's side, about 10ft to the right, 25 feet away...but everywhere else is really bad.
Old Sep 20, 2007 | 03:30 AM
  #150
hmm mine seem to work all around, I haven't really noticed it working in certain spots around the car. I just took mine apart to attach the original antenna (I peeled it off from the old remote) i have to test it out tomorrow.
