G35 & G37, Coupes & Sedans
45m/h local use 6th gear save gas or not?
Old Oct 14, 2006 | 10:36 PM
stevenwxw's Avatar
i drive 45m/h on the local road do i save gas by using the 6th gear?
Old Oct 14, 2006 | 11:24 PM
DaVince's Avatar
what actually matters is your cruising rpm.
the most efficient gas consumption is between 1700 to 2000 rpm.
if you go 2000 rpm at 6 gear I believe would get around 26-28 mpg
When I had my Navi on my 03. I was able to log in 25 mpg avg in city by keeping the rev around 2k.
Old Oct 15, 2006 | 03:12 AM
Msedanman's Avatar
O.F. Administrator
To me 45kph is too slow for 6th gear. That's only about 28mph and could cause damage to your engine.
You'd also have no ability to accellerate.
C.
Old Oct 15, 2006 | 05:54 PM
HokieZ's Avatar
C.
Damn canadians. j/k It's 45mph, not kph. 42mph is the recommended speed to shift into 6'th for optimum gas mileage so 45 is fine.
Old Oct 15, 2006 | 06:34 PM
DaVince's Avatar
yeh just downshift if you want to accelerate. Its saves more gas that by downshifting because you reach desired speed faster.
Old Oct 15, 2006 | 07:20 PM
excluesiveonez's Avatar
can some one explain how this will hurt the engine (i dont drive a manual so i dont know)
Old Oct 15, 2006 | 07:30 PM
kevink's Avatar
If you drive too slow for the speed, your engine can chug.
Old Oct 15, 2006 | 07:41 PM
DaVince's Avatar
not enough power to push the car because of the gear.
imagine on a bicycle with a higher gear going really slow and try to paddle it. Its tough right?
same way. Your engine will stall if your rpm is not high enough when you let go of the clutch from a stop.
Basically don't stress your engine and tranny. Operating it between 1500 and redline is fine. Shift when you should.
Old Oct 15, 2006 | 09:02 PM
jackygor's Avatar
The lower the RPM, the less work the engine is doing, therefore i assume the lower the RPM would yield better milage.
Old Oct 15, 2006 | 09:10 PM
DaVince's Avatar
you're right! but not too low rpm.
obender66
18 Inch
Mar 13, 2016 12:20 PM
mtlruss
Dec 20, 2015 01:51 PM
Frostbite91
Aug 20, 2015 07:20 PM
Blakearold
Aug 19, 2015 10:20 AM
HypedAndy
Aug 18, 2015 03:34 PM
