WTF my G is so much faster what happened?
#31
on
Originally Posted by Msedanman
You G's with dedicated summer rubber on be careful.....they don't work too well at those temps.....
That is cold for you guys......you must be freezin' your a$$ets off..
C.
C.
+1, I guess it's time for you guys Californians to finally buy a dedicated winter tires
#32
#33
#34
Originally Posted by infinitialex
Yea I do notice that its very easy to loose traction on the g even running on 225/55/17
Might have to upgrade to a 245 or at least 235 for the rear
No. It's the weather. When it's below 30, I can light the tires up in 1st from a roll and I get pretty decent 2nd gear spin on the 1-2 shift. From a launch, I can roast the tires through most of 1st while accelerating. Cold weather makes the rubber compound harder therefore you have less traction. The roads may also still have salt/sand residue.
#35
Learned Hand
10-01-2015 09:02 AM
