G35 & G37, Coupes & Sedans
Excessive Rear View Mirror Vibration.
Old May 5, 2007 | 03:39 PM
HLMAX's Avatar
My G is equipped with an auto-dimmer, Homelink rear view mirror. It tends to have excessive vibration on uneven roads, where the view using the mirror is blurred. It is much worst than my other cars. The mirror mount feels adequately rigid. On the same roads, the side view mirror remains clear and stable, so it is not the car's chassis. If I place my hands on the side of the mirror to stabilize it is fine.
Has other G owner have shaky rear view mirrors? Any fixes?
TIA
Old May 5, 2007 | 04:03 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
i have the same problem when i turn the bass up.. but who cares right?.. but actually being related to bumpy roads or anything.. nothin like that
Old May 5, 2007 | 07:24 PM
EZZ's Avatar
EZZ
I took my mirror apart and put a layer of masking tape (real thin) between the front panel and the mirror itself. The actual vibration is caused by the mirror tapping the front panel of the plastic housing. It fixed the problem completely and the mirror is now noise free. The front panel is a b!tch to take off and may cause marring if you use a screwdriver. There is a thread with someone else taking the mirror aprat.
Old May 6, 2007 | 01:48 AM
shooter's Avatar
It's not the critic......
You might be referring to this thread EZZ?
Check post #5
https://g35driver.com/forums/interior/51690-rearview-mirror-rattle-fixed.html
Old May 6, 2007 | 02:32 AM
ttrank's Avatar
Grocery getter
I have that problem but it is from the W6 and 1000/1. My homelink mirror is fine otherwise.
Old May 6, 2007 | 02:33 AM
SkyBlueG35's Avatar
TIA
mine shakes like a motherf*cker when i crank the bass but i have a 15" Kicker L7 pushin 950W
Old May 6, 2007 | 03:51 AM
HLMAX's Avatar
Check post #5
https://g35driver.com/forums/showthread.php?t=51690
Thanks everyone for their help and shooter for the mod.
My mirror is siliconed and ready to install in the morning.
The toughest part is separating the housing. Took it slow with a small stiff putty knife to avoid buggering up the plastic. The front trim snaps INTO the back, so carefully 'peel' the back housing out and the front trim will pop out. Start at top and slowly work around.
Old May 6, 2007 | 04:33 PM
ryn996's Avatar
I took mine to the dealership and complained about vibration noises in the interior. They replaced the shifter assembly (AT) and the rear view mirror.
Old May 8, 2007 | 01:35 PM
g35brandon's Avatar
good thread because I was about to post about it myself
Old May 10, 2007 | 11:19 PM
G-girl's Avatar
Staff ALUMNI
TIA
Have you taken it to your dealer? - Don't know if anybody has suggested it. The only time my rear view mirror shakes is when I have my music way up.
Old May 12, 2007 | 06:57 AM
fullofivy's Avatar
I had my dealer replaced the rear-view mirror soon after I got my car. Unfortunately, the replacement mirror didn't fare much better.
Here is what I did: using heavyweight plastic sheets (like ones for covering windows in winters, for ex.), I cutted a ~1/8" strip and inserted into the front-bottom of the mirror between the glass and bezel. This has worked well. At least now the mirror do not vibrate went simply driving on coarse road surface. There is a little when going over expansion joints and such. Simple and easy solution and it works well enough for me. My $0.02.
Old May 12, 2007 | 09:07 AM
OCG35's Avatar
TIA
It's inherent on our cars... you'll get use to it.
Old May 12, 2007 | 02:52 PM
Beebo's Avatar
ditto
mjfenix
Aug 17, 2017 05:49 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
