G35 & G37, Coupes & Sedans
What are your rpm's at 70mph?
Old May 22, 2007 | 05:22 AM
AgentAero04's Avatar
This question is for the stock G owners.
Just curious what you're rpm's are at 70mph?
I'm around 25-2600. I have aero and not sure if that makes a differance.
Old May 22, 2007 | 10:57 AM
SLVR JDM's Avatar
I want to say it is in the 2.5-3k range.
Old May 22, 2007 | 05:04 PM
Toxa's Avatar
gear?
Old May 22, 2007 | 06:31 PM
sloppymax's Avatar
might want to mention your tranmission type since most manuals will be lower than autos at the same speed. they typically idle 100-200 rpms lower.
Old May 22, 2007 | 07:56 PM
Auto trans-in drive not tiptronic mode,thanks.
Old May 23, 2007 | 10:58 AM
jayjay1122's Avatar
I have a bone stock 03 AT sedan and at 70 mph my RPM's are 2500 with a mild fluctuation of 50 RPM in either direction with Cruise Control set.
The only reason I can give you such a precise number is that I commute 60 miles each way to work and gas mileage, etc is VERY important to me and I find 70 mph to be the best compromise of fuel consumption and the amount of time it takes me to get home. ;-)
I'd rather do 80, but the almost 500 RPM drop to 70 has upped my gas mileage quite a bit!
Old May 23, 2007 | 12:04 PM
Texasscout's Avatar
05' sedan, 6th gear 70mph = 2900
Old Aug 13, 2007 | 02:21 PM
jayjay1122's Avatar
AgentAero04,
Just to add to this, I have been keeping track and checking numbers and with a slight variations, I can say that I am getting about 24-25 mpg on average. This was closer to 20mpg when I went 80 mph regularly!!
Obviously the advertised numbers from Infinity are BS, but 24 is better than I thought I was getting!!
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
alessandro
Oct 8, 2015 09:29 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
