G35 & G37, Coupes & Sedans
looking for larger oil filter for 05 coupe
Old May 27, 2007 | 08:56 PM
Bigd2k6's Avatar
i heard a while back that there's a larger filter from another make/model that fits our cars. anyone else hear this too? i'd like to see if it's worth picking up at autozone instead of our midget oem filter.
Old May 27, 2007 | 09:53 PM
Drtybrd61's Avatar
I believe the filter from the Maxima will fit our G's
Old May 28, 2007 | 09:18 AM
Bigd2k6's Avatar
what year(s)?
Old May 28, 2007 | 10:02 AM
G35 Mass's Avatar
I just got the Gold line NAPA maxima filter, it's the same size.
Old May 28, 2007 | 03:25 PM
redlude97's Avatar
the larger filter is ~1/2" longer than the stock filter
Old May 28, 2007 | 08:52 PM
LondonG's Avatar
Ask for a filter for a 98 Maxima. Those are the ones I use.
Old May 28, 2007 | 09:13 PM
Bigd2k6's Avatar
cool, thanks.
Old May 29, 2007 | 10:21 PM
Curt G's Avatar
You're looking for the Nissan 9E000 filter.
Old May 29, 2007 | 10:49 PM
GreenGoblin's Avatar
The goblin resurrection
how much bigger is it than stock
Old May 29, 2007 | 11:01 PM
Curt G's Avatar
For the 9E000 it's about the 1/2" stated above. It's used by the QX56, so it's designed to handle a much larger engine. I use them on my coupe so I know they fit fine.
Old May 30, 2007 | 10:49 PM
thank you I missed that one
Old Jun 27, 2007 | 06:51 PM
shdowflare's Avatar
What are the benefits to using a larger filter?
Old Jun 27, 2007 | 08:47 PM
redlude97's Avatar
more filtering area for a higher efficiency and more oil flow and higher capacity
Old Jun 27, 2007 | 09:03 PM
shdowflare's Avatar
I normally buy the K&N's that fit the G (forget the size/model #)...so should I look for a K&N filter that will fit the '98 Maxima?
Thanks...
Old Jun 27, 2007 | 09:10 PM
HokieZ's Avatar
Check out the M1-105. They barely fit but they do in fact fit. I bought 30 of them off e-bay and have used them for the past 4 years between my 350Z and G35C
