G35 & G37, Coupes & Sedans
Need a quick answer: swapping fuses
Old Sep 10, 2008 | 08:12 PM
RPL's Avatar
RPL
Sorry to make two threads, but I need the answer immediately. Here's the link: https://g35driver.com/forums/g35-sed...ing-fuses.html
Old Sep 11, 2008 | 10:28 AM
carfan76's Avatar
RPL
Swapping in larger fuses for smaller fuses is generally not a good idea. The wiring used in the circuit is typically sized for the circuit. A ten amp circuits wires are going to be much smaller than a 25 amp circuit. By swapping in a larger fuse you are in effect making the rest of the wiring in the circuit the fuse. The wires will not carry the amperage that the fuse will, thus melting the wire and creating some problems. Hope this helps.
Old Sep 11, 2008 | 10:32 AM
Hi-TechG35's Avatar
^+1
Old Sep 11, 2008 | 10:43 AM
G35Now!'s Avatar
Moderation-free
OP, looks like you have your answer (in this thread and the other one), closing this thread.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
