G35 & G37, Coupes & Sedans
Car beeps when starting
Old Dec 23, 2008 | 09:00 AM
Ghaleon0721's Avatar
I can't figure out what is wrong here.
This only seems to happen when I start moving from a stop. Just as the car begins to move, there is a 'beep' sound. There are no warning lights that come on, just the beep. The car runs normally thereafter though.
Could any of these be the cause
1) I just got my tires changed over to snow tires
2) My clutch seems to stick when shifting out of 1st gear. That is, after I'm moving, and I release the clutch, it seems to get 'stuck' during the last inch or so. It doesn't literally get 'stuck', it continues to release, it just feels a bit different. It's tough to explain, but this happens well after I hear the 'beep'
The owners manual provided no suggestions. Any ideas?
Old Dec 23, 2008 | 12:31 PM
OBG3506's Avatar
year make and model would help! my coupe will beep if the intellikey is like buried in my pocket with a half dead battery.
Old Dec 23, 2008 | 01:05 PM
2006 6mt
I don't have an intellikey
This only happens when the car is running, and I'm stopped, then start moving again. I'm wondering if it has something to do with the Tire pressure monitoring system, but there is no warning light. I'm also thinking that my tires could just be slipping since we just had a big snowstorm and the roads aren't 100% clear yet. But again, usually when that kind of beep occurs, I see the "SLIP" light blinking. Finally, I'm wondering if it has anything to do with my clutch. As I said, it seems to 'hang' just a bit on it's way back up after I start moving. But the 'beep' usually happens before the clutch reaches this point.
I called the dealer, they didn't have any ideas.
Old Dec 23, 2008 | 01:11 PM
Darkstar752's Avatar
It really sounds like your ABS doing a system check. Im not sure if it's supposed to beep though. Does the SLIP light stay on?
I'm like 90% sure it's the ABS system check, and it's beeping and more noticeable because of the snow/ice, maybe the cold temp too.
Old Dec 23, 2008 | 01:42 PM
pczavala's Avatar
check your brake fluid? or any other fluid
the only beep i get is when i sometimes leave the door open or the trunk, it will beep and then the navi tells me door open or trunk open.
Old Dec 23, 2008 | 02:00 PM
I only mentioned the slip light as a comparison. It's teh same beep I hear when my tires are slipping, only this particular phenomenon is not accompanied by the 'slip' light.
It's just a beep, without any accompannying warning light, that goes off as I take off from a stop.
It doesn't happen any other time, and i've been watching it closely for two days. It's been very cold and snowy here, but I don't know if that has anything to do with it.
Old Dec 23, 2008 | 03:47 PM
OBG3506's Avatar
I got an AT and when it slip it never beeps, something maybe wrong with my car! keep us posted on the outcome!!
Old Dec 23, 2008 | 04:05 PM
Beebo's Avatar
Is the low tire pressure light on? They may have broken one sensors on the wheels when they switched tires
Old Dec 23, 2008 | 04:11 PM
No lights are on. Just a beep when I start moving from a stop. That's it. No lights, no buzzers, no flashing signs. Just a beep.
Old Dec 23, 2008 | 04:46 PM
pattyskin's Avatar
is it a long drawn out beep like beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep or a short one like beeeeeep?
Old Dec 23, 2008 | 05:13 PM
Just a short beep. And it only happened when the car first begins moving.
Anyway, I just drove home from work and tried a few stops and starts. No beep. The problem is completely gone. The clutch doesn't seem to stick anymore either.
I'm wondering if it is just the temperature. It was -10 this morning, definitely much colder than it's been in a LONG time. Maybe the roads are just slick enough that the traction control would kick on, but not enough so that the light came on. Also, over the weekend I got the car stuck in some pretty deep snow, I'm wondering if it got up underneath the car somehow and froze, and that is part of my clutch problem.
It warmed up a bit today, so the roads are in better shape, and maybe that fixed my problem.
Wacky, just wacky
Old Dec 24, 2008 | 07:20 AM
OBG3506's Avatar
Man @ 10 below i wouldnt be surprise by anything a car does! Thats brutal enough to crack a block if you dont have the right antifreeze mixture!
Old Dec 24, 2008 | 09:02 AM
Mustang5L5's Avatar
At 10 degrees and under...cars do strange things. Sometimes my interior lights don't turn on when i open my door on a recent night when it was 5 degrees out
Old Dec 24, 2008 | 12:15 PM
It is without a doubt just the ABS doing a system check. It happens when the car first starts moving and never happens again, it's supposed to do it so you don't notice, but you will if it is so cold and icy.
chinee
Jun 10, 2024 07:48 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
kenthung
Jul 21, 2015 05:56 AM
realtalk21
Jul 20, 2015 09:07 AM
