G35 & G37, Coupes & Sedans
2 questions....!!!
Old Feb 11, 2009 | 06:09 PM
dann1313's Avatar
2 questions....!!!
i have an 03 coupe. it has navi. can i play dvd's on the navi. where you put the navi info dvd into can i put a movie in there and will it play???
also with my key when i hold down the unlock botton the windows go down,, can i use the lock button to roll them up???
please no negitive feedback
thanks guys!
Old Feb 11, 2009 | 06:56 PM
05DGx's Avatar
1) You can't play dvd's using the stock navi
2) The windows don't roll back up using the remote, you'd have to put the key in the door lock and turn to the locking direction and hold.
Old Feb 11, 2009 | 06:59 PM
05DGx's Avatar
Also check out these guys:
http://www.kptechnologies.com/produc...el=G35%20Coupe
They have some modules which you can use if you want to be able to roll up your windows via key fob.
Old Feb 11, 2009 | 07:17 PM
dann1313's Avatar
thanks guys.. for 50 bucks i can use the key fob to roll up the windows. good deal but install must be alot. and who would do that sort of install?
also what can i do to the stock navi to play dvd's? can i go to my local system shop and see if there is a bypass or something?
Old Feb 12, 2009 | 07:28 AM
OBG3506's Avatar
i think its against forum rules to discuss hacking into you navi for the sake of playing pornos while you drive, LMAO! Seriously tho!
Old Feb 13, 2009 | 10:14 PM
dann1313's Avatar
haa naaa not for that thats what my girl is for.. i dont need that ****. ha good one though
Old Feb 14, 2009 | 12:45 PM
KPierson's Avatar
Check out this thread for converting your system to play videos:
https://g35driver.com/forums/audio-v...play-dvds.html
The KPtechnologies window module isn't too difficult to install - most people either do it themselves or have a friend do it. Most audio shops would be able to complete the installation as well - there are only five wires in the drivers door that need to be hooked up.
silencedeyes
Engine - Complete Motors
Feb 25, 2014 08:16 PM
Nightm4re
Oct 12, 2012 02:59 PM
GR6RR
Jan 4, 2011 04:54 PM
djthart
Jun 3, 2010 03:07 AM
kujoG
Apr 19, 2010 08:39 PM
