Volk GT-7 19" wheel spacer question.
Hey guys. I've recently bought Volk GT-7 19". i don't know what offset it is, bought it used from local body shop mechanic. he was installing the rims without the spacers on my 04 G coupe which has brembo brakes and ended up leaving curb rashes right below the BREMBO lettering. he said he would paint it for me but will it be noticeble badly? any also, what thickness of spacers are needed to clear out brembos. I NEED HELP !
if its 30 .. it would clear .. try a 5mm spacer .. if it just brushed the caliper then 5mm should def clear .. if the clearence is real bad .. the wheel wouldnt even turn, it would just hit the caliper and stop .. if the stickers are still on the inside of the barrel it will tell you the offset
yeah... i just thought that too. i see that wheel just scraped caliper paint all around and that means it is slightly touching the caliper. so... i'll throw in 5mm spacer. but now.... can i trust autozone or pepboy's spacer?
Gary
FS[Canada]: 19" Rays Volk LE37 Wheels Rims with Falken Tires
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
