G35 & G37, Coupes & Sedans
Help! I'm locked out of my car!!
Old Jul 13, 2009 | 01:11 AM
IInfinitII's Avatar
I was heading out to my car to go to the gym but I couldn't unlock my doors.As of right I'm assuming that my car battery is dead. I even tried using the manual key to unlock the doors but the key wouldn't turn? WTF? I also tried using the spare key and it still wouldn't work. Anyone have any suggestions?
Old Jul 13, 2009 | 01:49 AM
paolotonzini's Avatar
i had to use a coat hanger last night sucked!!!
Old Jul 13, 2009 | 02:14 AM
HwyDrftr's Avatar
Sure it's the right car? lol
Old Jul 13, 2009 | 02:31 AM
IInfinitII's Avatar
hrmm I should go check. lol
Old Jul 13, 2009 | 07:02 AM
WhosUrBuddiee's Avatar
Try the trunk
Old Jul 13, 2009 | 12:34 PM
falcor's Avatar
shoot some WD40 into the door lock... run the key in and out a few time... repeat the process a few more times... this should be enough to clear any gunk out of the lock and allow it to turn
Old Jul 15, 2009 | 03:41 AM
PublicEnemy's Avatar
The only other thing worth mentioning is...
Do you have the ikey system? If so I'm thinking the fob you have is a replacement that wasn't cut for your car.
Old Jul 15, 2009 | 01:07 PM
Todd157k's Avatar
I believe the key door locks only actuate the electrical door lock. Therefore, if you have a dead battery, they won't work.
What you can do is take off one of the rear light lenses, either tail light or license light, and the bulb. Hook up a 12v battery to the leads of the light. MAKE SURE THE + AND - ARE CORRECT.
Then you can use your key in the door.
Old Jul 15, 2009 | 09:46 PM
parhamm1's Avatar
Make sure you have the right keys! (jk)
Old Jul 16, 2009 | 03:12 AM
IInfinitII's Avatar
I got roadside assistance to come out and open my doors. I do have the ikey but the thing i don't get is why does the manual key works in the ignition but not the doors?
Old Jan 17, 2020 | 01:02 PM
Ernesto Orozco's Avatar
Infiniti G35
Did you ever get this issue resolved? I am having this same issue, unlocked my car just fine a day ago and this morning I was heading out for work and my car wouldnt unlock using the key. It wouldnt turn in the lock. Ive browsed a couple different forums online but havent came across to the answer for this question. Any idea of what this might be?
Old Jan 17, 2020 | 09:31 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
What's the weather like? I've had lock cylinders freeze internally before.
Do you normally use the key to unlock the door manually or was this a one-time thing? If it used to work but suddenly doesn't then your key may be significantly worn. You can have a locksmith VIN cut you a new key and then swap the RFID transponder to the new key so it won't require programming.
Here is a picture of one key I'm currently using that I did this to, you don't have to chip the plastic like I did but it makes it a hell of a lot easier.
And here is a video of a guy doing the same thing.
Old May 19, 2020 | 10:09 AM
noahgrace's Avatar
na
This video is really very helpful for me and it can save money from hiring a locksmith.
mike730
Jan 12, 2018 04:25 PM
apintojr
Jul 23, 2015 10:52 AM
realtalk21
Jul 20, 2015 09:07 AM
mushu
Jul 15, 2015 03:55 PM
