G35 & G37, Coupes & Sedans
Anyone know if our G's can take a larger oil filter?
Old Nov 21, 2009 | 12:21 AM
jibberjabbers's Avatar
If so, which oil filter and from what car?
Old Nov 21, 2009 | 12:26 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
you can use the filter from an 04 Maxima.
Old Nov 21, 2009 | 12:41 AM
Jeff92se's Avatar
Red Card Crew
https://g35driver.com/forums/g35-sed...ice-price.html
Old Nov 21, 2009 | 02:08 AM
thescreensavers's Avatar
Mr.202?
M45 filter is 1inch longer and fits our G
Old Nov 21, 2009 | 03:23 AM
umair's Avatar
https://g35driver.com/forums/engine-...ilter-g35.html
go to page 4
Old Nov 21, 2009 | 11:46 AM
1sweetg35's Avatar
Is it recommended to run a bigger filter? Won't hurt anything will it?
Old Nov 21, 2009 | 12:11 PM
Mustang5L5's Avatar
That is a legit concern. I'd imagine the larger surface area of the filter would result in a slightly lower pressure drop across the membrane resulting in perhaps slightly lower engine oil pressure? But i'm talking 1-3PSI, which may be negligible in the grand scheme of things.
Of course, without an OP gauge, and running both filters back to back, hard to say if this is true.
Old Nov 21, 2009 | 01:43 PM
umair's Avatar
all you need to know... bigger = better lol
more filter guys... higher burst pressure... look at page 4 on my previous link
its got all the info there!
Old Nov 21, 2009 | 02:12 PM
binder's Avatar
larger filter means more media...more media is good.
i use the filter for the fx45 which is a Mobil m-110. It's about an inch longer than the recommended filter for our 3.5 liter (m-108).
Old Nov 24, 2009 | 12:48 AM
Morovasa's Avatar
Its a great idea... I have done it with every car I have had..
Doesnt mean you can prolong the oil changes but will keep the oil cleaner for the time/miles driven
Old Nov 24, 2009 | 04:05 AM
pfarmer's Avatar
A lower pressure drop across the media could result in a higher engine oil pressure in a full flow system. In a partial bypass system with filtered oil flow bypassing the engine the reverse would be true unless orificed to prevent it.
Old Nov 24, 2009 | 04:14 AM
accordfreak's Avatar
i had a few extra honda japanese oil filters. twice the size of the oem one. used them all up with no issues.
Old Nov 24, 2009 | 08:15 AM
EL-EE-ES's Avatar
i use wix filters
Old Dec 26, 2009 | 07:04 PM
PTownG's Avatar
K&N HP-1010
It's the M45 filter.
I've'd used nothing else since I got the car
Old Dec 26, 2009 | 07:11 PM
Swivel's Avatar
Moderator
Amsoil EAO13 or Wix 51356 here (larger size)
