G35 & G37, Coupes & Sedans
why am i rubbing?
Old May 28, 2010 | 11:06 PM
kennymo's Avatar
why am i rubbing?
so i just intalled 15mm spacers on the front of my sedan. so my setup for the front is now 20x8.5 20offset. i have 245/35/20s and am dropped on 350z stechs. and i rub VERY BADLY. even when going in a straight line. if it hits a bump, it rubs. i didnt think it would rub nearly that bad. is this normal? do i maybe just need to pull out the very top bilt on the outside edge of the inner fender? i will eventually get some 225/30/20s but i can not afford to jump on new tires right this minute. thanks
Old May 28, 2010 | 11:09 PM
CandlestickPark's Avatar
ill Sedan
Removing the two fender screws with definitely help. I just removed mine today because after going lower I was rubbing against the fender screws really bad (made a really loud noise when I turned). I'm still rubbing up front but not as badly as before. I am at 19 x 8.5 +15 up front.
In order to stop rubbing completely you likely need a smaller tire size and/or more camber.
Old May 28, 2010 | 11:14 PM
kennymo's Avatar
2? where is the second one.
i know of the one in the center of the fender thats right on the edge. where is the other?
Old May 28, 2010 | 11:21 PM
ill Sedan
Feel along the inner part of the fender right at the edge as you described. When I removed mine today I had two. I thought there was only one too but for some reason I had two. BUT, there weren't any on the passenger side so maybe I had them both installed on one side, not sure. If you only feel one and remove that one, then your good.
Old May 28, 2010 | 11:24 PM
kennymo's Avatar
ok cool thank you. ill go do that right now and then report back.
Old May 28, 2010 | 11:27 PM
G35Papa's Avatar
Your rubbing where the fender and front bumper bolt up Kenny. Take a look just behind your side marker, you will probably see the edge of the where the bracket meets the fender bent downward. You basically need lower profile tires or to remove the spacers. Negative camber might help a bit too...that means front camber kits.
Old May 28, 2010 | 11:57 PM
kennymo's Avatar
ok so i took those 2 bolts out you were talking about and that helped tons. it barely rubs now. now it only rubs when i make a turn and hit a dip in the turn. i think i can get away with dropping down to a 235/35/20. if they even have that size.
chris that bracket is kinda far forward isnt it? the tire will hit something way up there?
Old May 28, 2010 | 11:59 PM
ill Sedan
^Nice, glad that worked for you. Be careful in the turns. You don't want to hit a dip too hard with your wheel turned. Get some smaller tires when you can to stop the rubbing completely.
Old May 29, 2010 | 12:03 AM
kennymo's Avatar
yea thanks for the help. and yea smaller tires are definatly on my list. just sucks because these tires are almost new. i guess i could sell them.
Old May 29, 2010 | 01:00 AM
G35Papa's Avatar
Yeah, it will depending on what size tire you run and how dropped you are....oh and how flush you are too Glad you got it solved though.
Old May 29, 2010 | 01:07 AM
kennymo's Avatar
haha well the tire is definatly poking at the moment. but i think if i was to drop it a little more it wouldnt be poking so much. im contemplating on those spacers you have though. not sure if i wanna do 5s or 10s for the rear. and ill check that bracket out tomorrow and see if thats rubbing. thanks for the tip
DRG35R
Jan 31, 2016 07:14 AM
Popes
Sep 28, 2015 05:14 AM
alinero718
Sep 27, 2015 09:35 PM
