G35 & G37, Coupes & Sedans
is the g35 vq engine supposed to sound like its about to explode?
Old Jul 26, 2010 | 02:49 AM
kday's Avatar
take off the exhaust and drown out all the other sounds
Old Jul 26, 2010 | 06:48 PM
usafdarkhorse's Avatar
Originally Posted by 4DGS
^ not so much, chains snap and takes a lot with it, belts snap and the car isn't too hurt, you'll replace more when a chain snaps than when a belt goes.
Belts also give you a warning (fraying and noise) chains don't, they just snap.
A belt will hurt as much as a chain regardless. It's the interference vs non-interference engine that matters for what's broken.
If you're waiting until you see fraying and noise to replace a timing belt, you're in trouble. Most belts that need changing will never indicate it until you've pulled it off the car and have cut it open.
Old Jul 27, 2010 | 08:10 PM
CreativeDesignZ's Avatar
what does a chain take with it that a belt doesnt? Either way the engine is probably toast. Belts dont always give you warnings either...its the same both ways and they are both equally as detrimental to an engine.
TWASkyliner
Feb 8, 2020 08:00 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
ghost_g35
Aug 7, 2015 10:31 AM
laksjd84
Jul 24, 2015 05:12 PM
