Do I NEED spacers to put G37 Wheels on my G35 Coupe?
Just ordered a set of G37 wheels that I want to put on my G35 Coupe. Do I absolutely need spacers to put them on? Can I not drive the car or put the wheels on safely and effectively without spacers? Or are spacers more for the look?
Please help. Thanks!
ToDie4G35Coupes (08-10-2011)
Thanks for your help by the way.
EDIT:
It looks like this white G35 Coupe has them without spacers on so I guess it's still driveable without spacers, just not very appealing. Can someone please confirm?
https://g35driver.com/forums/wheels-...g35-coupe.html
I drove ttrank's car solo
spacers serve an aesthetic purpose. otherwise, they are not required for the car's wheel to be functional, neither are they required from a safety standpoint. Having no spacers on the car will not damage your car in any way. Because you wouldnt have the spacers on, your new G37 wheels will look sunken in. You can order spacers at a later point in time. To figure out the correct size of spacers to order you need to consider the following:
- f/r wheel width & offsets of the new g37 wheels
- are you planning to drop the car at all, or keep it stock height
- there are additional factors to consider if you are planning to go low (camber, tiresize, etc.)
The following 2 users liked this post by dcityjatt:
Keggr626 (08-10-2011),
