The most gas Ive ever pumped into my G
was running on empty, i know its not good but anyhow, i know our take is 70 liters, but i was able to pump 73.31400 litres (19.36 gallons). could have maybe gotten to 74 had i not hit the 100$ pump limit. how big is the tank really? anyone ever pump more than that?
I drove ttrank's car solo
We don't really have a typical filter, it's more of a screen in the gas tank the gas passes through. Regardless, why take a chance getting something you don't want in your motor when all you need to do to prevent it is never let your tank run almost bone dry? Seems like a good idea in my mind.
Well, figure the fuel line is has .25 cm radius, it has to run from the tank to under the motor, then up to the injection system, so maybe five meters. That's 98 cm^3, 98 mL, ...which would fit pretty precisely to the extra .1 liters.
