well its going to be pretty much the same as doing a dual ring install. its just this will be much cleaner. i mean you still gotta open up the tail light, and cut off the existing ring but that is pretty much it. the led pcb has holes so the bezel will snap in and then the bezel has holes so the diffuser lens just snaps in.
i know the lens is still not totally clear which bothers me, even though i polished this thing for a long *** time. i just bought a bunch of silicone and resin and am going to try to cast this 3d print in crystal clear resin to get a better result.and then i gotta send the bezel off to get chromed.
lol i wasnt really intending to mass produce these to sell. there was just a minimum order qty on custom pcbs so i tagged em with my name haha. i only have 4 extra sets. buying all the resistors and electrical pieces from digikey now.
edit: showing fitment on the last pic. i still have to trim the edge of the bezel just a bit for a totally flush fit. there isnt very much room on the side of the opening so its gotta come super close. havent gotten around to trimming yet bec i was waiting for these pcbs to come in and get the orientation right first
im drunk. first person to guess what number im guessing 1-10 gets a free shirt. just pp 4$ for shipping
Quote:
Your number was 7. Btw. We got the shirt you sent. The gf loves it! Just wanted to say thanks.Originally Posted by .cakestar
Quote:
Sweeeeeeeeeet!!Originally Posted by .cakestar
hhahahahahah you sir win another shirt
Quote:
Without replacing the diff bushing, a A poly trans mount and RR diff brace. Also good RR shocks.Originally Posted by austinfuentes23
How do I fix my rear tires bumping up and down instead of spinning while burning out?
Having both I must warn you the trans mount will induce a Subaru exhaust sound and vibrations in your cabin. Lol
Frankieg35
close
- Join DateOct 2006
- LocationSouth Jersey
iTrader Positive Feedback98
iTrader Feedback Score(41)
Liked:857 Times in 745 Posts
So nice!!
LoSt180
close
- Join DateMar 2011
- LocationMaryland
iTrader Positive Feedback100
iTrader Feedback Score(11)
Liked:468 Times in 379 Posts
Quote:
Replace your rear shocks, it's the most common cause. Other causes are blown diff bushing (the bushing is liquid filled and can blow out), and less common is bad rear suspension bushings.Originally Posted by austinfuentes23
LoSt180
close
- Join DateMar 2011
- LocationMaryland
The LED mastership is too damn high!Originally Posted by .cakestar
well its going to be pretty much the same as doing a dual ring install. its just this will be much cleaner. i mean you still gotta open up the tail light, and cut off the existing ring but that is pretty much it. the led pcb has holes so the bezel will snap in and then the bezel has holes so the diffuser lens just snaps in. i know the lens is still not totally clear which bothers me, even though i polished this thing for a long *** time. i just bought a bunch of silicone and resin and am going to try to cast this 3d print in crystal clear resin to get a better result.and then i gotta send the bezel off to get chromed.
Frankieg35
close
- Join DateOct 2006
Quote:
You make these?? Are you going to be selling them?Originally Posted by .cakestar
cleanest dual ring tail light setup? this one will replace the stock controller board, has an extra port for the extra ring so it will be plug n play. also has an extra port to integrate the turn signal wire and will have the second ring work as the turn signal. and also an extra port for an led drl for the light on the side. like the sedan
i have a few extra sets of the pcbs and controller boards. if i can figure out how to resin cast the lens and it comes out good i can probably sell a few.
