G35 & G37, Coupes & Sedans
Old May 1, 2016 | 11:30 AM
  #6106
Frankieg35's Avatar
Originally Posted by JKL1031
This is all I have for now. I have Berk HFC motor dye mrev and 5/16, K&N z tube, uprev
G35 Invidia - YouTube
Sounds good.. Has a nice deep tone.. Was gonna pair it with the berk HFC, ztube and 5/16 spacer also..
Old May 1, 2016 | 03:51 PM
  #6107
JKL1031's Avatar
Here is some hooning
Old May 5, 2016 | 05:55 PM
  #6108
mcdavidbranson's Avatar
I drove it from Houston to Dallas !
Old May 5, 2016 | 10:19 PM
  #6109
LoSt180's Avatar
Replaced the PCV houses with ones from z1motorsports. When doing tune up last weekend I noticed the stock one was torn going into intake. Got hose that matches up with my z-tube, actually fits much better now.
Old May 6, 2016 | 04:06 AM
  #6110
.cakestar's Avatar
Ever wonder why there is a light sensor on the front of the rear view mirror? the one on the side of the buttons is to control auto dimming of the mirror which makes sense but why is there one facing the road??
oh... it's to control the illumination of the back lit buttons....
Old May 6, 2016 | 08:32 PM
  #6111
JG_G35's Avatar
Received my Stance Coilovers today. I'll be installing them tomorrow morning.
Old May 7, 2016 | 08:11 AM
  #6112
vashawn's Avatar
Clay bar, compound, polish wax buffed rims
touch up all paint chips.
Old May 8, 2016 | 07:26 PM
  #6113
slicrick's Avatar
Cleaned it and took it for a drive.
Old May 8, 2016 | 08:33 PM
  #6114
Urbanengineer's Avatar
And the dimming of the mirror right? Mine turns blue because my parking pass blocks it during the day. Had me confused for a while.
Old May 8, 2016 | 09:35 PM
  #6115
JKL1031's Avatar
so the leds in our speedo are soldered in? i have some that have gone out.
Old May 10, 2016 | 03:03 AM
  #6116
.cakestar's Avatar
wait! im confused. your stock rear view mirror had light up buttons? the front photocell controls the illumination of the buttons. the auto dimming is controlled by the photocell on the same side as the buttons. there are two photocells
  #6117
.cakestar's Avatar
which year? but yes they are soldered in. but depending on the year you will need different leds to replace
Old May 10, 2016 | 09:05 AM
  #6118
LoSt180's Avatar
Now I'm confused, I thought the illumination of the buttons was controlled the same way as all of the other buttons (via light switch) and the two photocells worked together to control the dimmer. So if the front was dark but the back was getting hit with light, then the mirror would dim. Blocking that sensor, with a parking pass for example, would cause the mirror to dim (turn blue) because the sensors think it's night time and there's a semi-truck with hi-beams ridding your rear-end.
Old May 10, 2016 | 03:30 PM
  #6119
JKL1031's Avatar
I Have a 2005
Old May 10, 2016 | 04:44 PM
  #6120
.cakestar's Avatar
so stock, the mirror has no illumination. dont think any of the g35/350z for any year has a model that has illuminated buttons. there are places for leds to be soldered on and you need to get power to them. the front photocell is connected to the logic chip that when it is dark outputs a 5v signal to a transistor that connects power to the leds. only the photocell on the side or the buttons affects dimming.
