G35 & G37, Coupes & Sedans
Old Dec 4, 2016 | 05:58 PM
  #6751
Swaglife81's Avatar
Put on some new Morimoto XB blinker LEDs and city lights for the OEM projectors. Also had to put in some load resistors.
Did I pay $10 apiece for em?
Hell no!
Made my own with a 10 Ohm 1 Watt load resistors with 1/2" PVC and some soldering. Wired in parallel with blinker circuit. Handles heat well.
$1 for resistors and $2 for PVC & 8 caps. Makes four for the four corners.
I really want to make some LED dual rings though. Those are Niceeee!
Are the resistors just for the load or for can-bus friendly reasons. I'm new to these cars. You should do a full DIY guide. You already have pics.
I have 03 Bi-xenon factory HID lows but my main concern is trashing the amber turn signal lense and a clear lense in its spot. It looks like you replaced the lense in the pics. Was it hard to do
Old Dec 4, 2016 | 06:32 PM
  #6752
.cakestar's Avatar
it's just for load, for the hyperflashing in the turn signals
Old Dec 4, 2016 | 09:41 PM
  #6753
Mr. Brooks's Avatar
After upgrading the brakes on my G35 to Akebonos. Is the factory spare able to fit the car.
Old Dec 4, 2016 | 10:50 PM
  #6754
Urbanengineer's Avatar
Originally Posted by .cakestar
also load resistors arent too bad lol
http://www.ebay.com/itm/4-PCS-50W-Lo...dTo4yz&vxp=mtr
Shoot! Well I wanted to save a little wattage and this was my way of doing it. I stepped up the resistance until the hyperflash went away.
This way the LEDs reduce wattage used... also the city lights are now LED.
I like to think I'm saving the battery because of all this wattage the sub pulls lol.
03-04 non projectors have an HID main low beam and a halogen high beam.
The term Bi-Xenon means a projector that acts as a low and high beam. It activates high beam mode by moving a shield (that blocks light during low beam operation) out of the way. Much less wattage and allows for just one bulb this way!
These bulbs had can bus error cancellers, not a G35 problem.
As for the lens, it comes stock clear on the 05+ projectors. You may replace that amber lens with a clear one (glass most likely).
Old Dec 4, 2016 | 10:57 PM
  #6755
Most likely not, as BBK's usually require a full sized spare. You have a coupe?
Old Dec 4, 2016 | 11:03 PM
  #6756
AlexxG35's Avatar
I installed the fast intentions exhaust that I got from Nick05LS. Got straight pipes from the cats to the muffler.
Old Dec 4, 2016 | 11:49 PM
  #6757
.cakestar's Avatar
who needs a battery anyway
Old Dec 5, 2016 | 07:14 AM
  #6758
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by AlexxG35
I installed the fast intentions exhaust that I got from Nick05LS. Got straight pipes from the cats to the muffler.https://youtu.be/dXzcvPwy4rQ
So you got it, congrats!! How do you like it so far? When you buy a new exhaust there's a "break-in" period where the tone will change but since yours is used it should keep the same sound. Great purchase, my guess is this forum won't see a deal like that again for a while.
Old Dec 5, 2016 | 12:57 PM
  #6759
Swaglife81's Avatar
Seems one of my replies isn't showing up. In a couple weeks I'm gonna have almost a week off so I'm gonna get a chance to jump back on the car.
I'm gonna get a new DA Polisher as a Xmas present for myself and a my car is gonna get some attention with some real paint correction. So it's time to color match paint the door handles, mirrors.
I need your opinions. Everyone seems to Black out the window/door chrome trim. What do you guys think of color matched pillars and chrome trim instead. Car is KYO brilliant chrome silver
Old Dec 5, 2016 | 05:01 PM
  #6760
AlexxG35's Avatar
I love it! I did notice a loss of low end torque but I think getting a X pipe should fix that.
Old Dec 5, 2016 | 07:54 PM
  #6761
Swaglife81's Avatar
Can someone please tell me what trim ring this is from. Looks great rather than the boot going over the factory bezel. Just guessing but this look likes the 350z AT5 trim ring. Correct me if I'm wrong because I'm ordering one ASAP if so.
This isn't my car but would love to have this wide body kit. Car in pic has 295's sitting on it in the rear. That rear bumper is sex on a G Sedan. Anyone have a name on this kit. I hate the factory 03 front and rears
I don't want to do things twice and I'm ready to get some bigger things going on my car. This thread and the media share G Sedan thread have me so motivated
Old Dec 5, 2016 | 09:20 PM
  #6762
AlexxG35's Avatar
Can someone recommend a differential swap for a 2006 coupe 5at?
Old Dec 6, 2016 | 05:40 AM
  #6763
Blue Dream's Avatar
I swapped my 3.3 for a 3.5 from a 6MT 06 coupe. If I did it again I'd go up to a 3.7, but read the big thread on diff swaps. 3.5's are a direct bolt on but with the 3.7's some are and some aren't due to a different flange and extended shaft. Just do your research and you'll make the right call.
Old Dec 6, 2016 | 12:02 PM
  #6764
Mignav01's Avatar
If you're gonna swap, isn't a quaife the way to go? For all the trouble. But I've never done it, only read some reviews
Old Dec 6, 2016 | 12:44 PM
  #6765
Swaglife81's Avatar
Originally Posted by LoSt180
Playing around with new ARC features from Uprev and getting logs to adjust tune. After a few launches with launch control, I'm pretty sure I've roasted the factory clutch. The smell confirms it. Guess I'll be babying it until I can get it replaced.
Any clutch kit recommendations?
I say JWT. It's a good driving clutch, hold for drifts, street able but a upgrade from stock. Will work with stock flywheel. Now is the time to upgrade flywheel IMO.
Clutches are like exhaust though. People have different opinions. Besides recommendations. Do some research on personal reviews of clutches. Just to because different people have different needs or wants from a clutch. I drove clutch cars for 12-15 years straight and those high stage, high torque capable clutches just weren't friendly in a daily driver way
