Greased the suspension on my G, took off the passenger FUCA and greased the bushings better, I must have gotten a little lazy when I initially greased them on install because it's always had a very light "creaking" sound when going in and out of steep driveways. Totally quiet now.
I forgot to grease AROUND the bushing, the grease serts are fine for the regular 5k re-grease but the initial greasing you want to coat the bushing where it touches the FUCA because that's usually where the pivoting takes place and it's best to just do it manually to make sure you have good coverage, I had a big dry spot on one half of one bushing because I must have forgotten that one.
Swapped out diffs. Swapped out the diff bushings while I was at it. Subframe bushing was a total b*tch as was the left bushing in the diff. Swapped out the rear sway end links which btw were a total b*tch as well. All in all, great bonding time.
You'll get a lot less rear end shimmy and predictable power now. Congrats!
It is not harmless fun. Racing and exceeding the speed limit on public roads and bragging about it on a public forum just encourages others to do such a stupid thing.
What would you do if the police confiscated your vehicle in addition to the ticket, fines and possible jail for reckless driving?
Telcoman
Reason: against forum rules
