G35 & G37, Coupes & Sedans
Old Jun 2, 2018 | 09:51 AM
  #8416
Narutonish's Avatar
Originally Posted by Scorpi0
I have the same adapters and one of the holes wouldnt line up with the factory holes. I had to customize it a bit.
I haven't had any problems with fitment !!!
Old Jun 2, 2018 | 09:31 PM
  #8417
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Modified the seatbelt guide bracket, holy cow I should have done this a LOOOOONG time ago. No more seatbelt hitting me (or my wife) in the neck!
https://g35driver.com/forums/interio...-06-coupe.html
Old Jun 2, 2018 | 10:55 PM
  #8418
Edgarc6789's Avatar
That's pretty smart that's one of the biggest issues I have with the interior it's always on my neck
Old Jun 3, 2018 | 01:59 AM
  #8419
SAMzG35's Avatar
G35
Is this a generic bracket for all aftermarket speakers that size?
Old Jun 3, 2018 | 02:17 AM
  #8420
Narutonish's Avatar
Old Jun 3, 2018 | 06:55 AM
  #8421
JZ39's Avatar
I got a check engine light for crankshaft sensor, which was just replaced with oem last year, so I didn’t think that was actually the cause. I read up on the code and oil pressure is a critical aspect of this code, so I checked the level in the old oil burner...
Well, something has definitely changed since the last oil change. I was religiously at one quart for 2500 miles until around 125k miles and then it went to one quart per 1000 miles till 155k miles.
This time, the oil was pretty much gone! When I put some oil in, I could hear it hit the bottom of the pan!!
Pretty sure that’s bad
So, now starting the process of looking for a new motor. I’ve seen on the SOHO Motorsports site that they have some really nice remanufactured engines. I think when I do this, I’m going to do the long block, engine mounts, all hoses, radiator and fans. If I do this, I want to do it right. I don’t want to put in an old engine and run into all of the same problems down the road.
Anyone else have recommendations for good remanufactured engines?
Old Jun 3, 2018 | 08:38 AM
  #8422
Albanian122's Avatar
thinking of these for my g Coupe
Old Jun 3, 2018 | 09:21 PM
  #8423
.cakestar's Avatar
anyone got an 06 coupe passenger headlight with a lens that is not peeling or losing clearcoat on the inside? dont care about tabs
Old Jun 3, 2018 | 10:49 PM
  #8424
99champ's Avatar
Mine is a 2004 coupe. I think most websites I have done research on say that they're the same as the map lights.
Old Jun 3, 2018 | 10:56 PM
  #8425
99champ's Avatar
Originally Posted by Silversleeper86
Super easy. All you need is a butter knife. Just pry outward from the side, and yes, at least on the 2nd Gen Sedans, the bulbs are the same.
Attachment 258991
Okay thanks. I have an 04 coupe and I think i need to jiggle the whole housing unit out. It appears your light covers stick out more than mine like almost convex while mine kind of sit further up in the door panel.
Old Jun 4, 2018 | 09:04 AM
  #8426
Urbanengineer's Avatar
Neat. I'll use metric tho.
Old Jun 4, 2018 | 01:22 PM
  #8427
cleric670's Avatar
BANNED!!!
Yeah the only reason I went 1/4-20 is I didn't have any metric taps handy in my basement and didn't want to drive to the shop for this project.
Old Jun 4, 2018 | 01:45 PM
  #8428
eazdaskeez's Avatar
Had the tire patched today
Old Jun 4, 2018 | 02:08 PM
  #8429
cswlightning's Avatar
You have just sold me on the Panamera running lights. They don't look rice at all, very high end looking. Definitely going into my eventual retrofit that will be happening after rust repair and before front end wrap.
Drove the coupe 500 miles this weekend with 4 passengers and their luggage onboard. Averaged 21 MPG highway going 85 the whole way. Lots of drone when loaded down with people, only solution is to downshift often and keep the revs around 3k cruising and all is well! Duct tape patch is holding up too, the Eastwood frame coating I was waiting for arrived while I was up at Acadia so that's a project for later this week.
Old Jun 4, 2018 | 03:00 PM
  #8430
eazdaskeez's Avatar
Thanks!
