G35 & G37, Coupes & Sedans
Old Jun 7, 2018 | 11:49 PM
  #8446
Edgarc6789's Avatar
Originally Posted by cswlightning
All my motor mounts pretty much ARE destroyed... My gear selector jumps around like crazy whenever I go WOT at low speeds and I've got more vibration than acceptable for a "luxury" car in the cabin.
I have a pair of ebay OEM replacement mounts that I was going to throw in until I realized how hard engine mount replacement is on the G. Part of why I want to keep the dampener is because it reduces stress on the mounts and might prevent mine from giving up all the way.
Did you DIY or pay someone to do yours? If I could get it done in less than 3 hours I'd do it but since everything still works fine as of now I'm in no rush to do them. If I wait long enough maybe I'll have money for something that isn't ebay.
My mechanic did it for me he did it all in one day. I bought some cheap motor mounts from some random parts store I didnt expect much out of them but its I've a few months already and everything is still good
Is it true rwd motor mounts last longer than fwd motor mounts ?
Old Jun 8, 2018 | 12:34 AM
  #8447
Urbanengineer's Avatar
Contacted a welder about some TIG repair on an exhaust component I finally bought.
Old Jun 8, 2018 | 02:13 AM
  #8448
LoSt180's Avatar
Anyone know of a supplier who stocks small hydraulic dampers in various sizes available to consumers? Wouldn't mind getting a quality adjustable damper to replace the ebay one that broke, but definately not worth the money to me for a brand name part.
Have you taken one apart yet? Definitely not hydraulic. Looks like 2 EnergySuspension endlink bushings crammed into a cylinder. I think I have one in my garage somewhere that I removed.
One mount that will help shifting is the z1 trans mount. Beware though, lots of new noises come into the cabin. I thought I had an exhaust leak for a week before I realized it was the new mount. You can also get a stock style one from rockauto. Trans mount is pretty easy to replace.
Old Jun 8, 2018 | 08:37 AM
  #8449
cswlightning's Avatar
I haven't had a chance to pull the broken damper but that delrin ring you can see in the cylinder I believe is the bump stop, if you pull it out you can see the piston and the seal. If I can't get it to seal up I might actually do that and cram rubber into the cylinder and try and make a semi-solid connection at that point just for engine mount reinforcement.
I've already put in an ebay oem style trans mount, I didn't noticed much of a difference from my semi-blown old one but maybe that's just the old motor mounts taking up the slack... weakest link etc.
Would have been super easy to do if only I didn't have to remove my entire exhaust to get to it!
Old Jun 9, 2018 | 12:04 PM
  #8450
Silversleeper86's Avatar
G35 Sport Sedan 5AT
One thing I don't like about the G is that the rear turn signals are red, and they're red inside of red when the lights are on. I wouldn't mind if they were LEDs like the rest of the taillight. Because of that I feel like it's hard to notice in the light of day. So, I swapped to LEDs from Diode Dynamics. They have 3 different levels of brightness to choose from. I picked the middle. It's the HP11 which they rate at 310 lumens. They have red and amber colors to choose from. Definitely brighter and more noticeable than the stock bulbs! Super easy to install. Would recommend!
https://www.youtube.com/watch?v=A2Fn...ature=youtu.be
Old Jun 9, 2018 | 12:38 PM
  #8451
Edgarc6789's Avatar
That is bright
Old Jun 9, 2018 | 07:12 PM
  #8452
FirefighterG35's Avatar
Installed some JDM Skyline paddle shifters. Already having tons of fun with this mod.
Old Jun 9, 2018 | 10:35 PM
  #8453
Ooh neat. I could use that. Two hands on the wheel would be nice.
Old Jun 10, 2018 | 01:13 AM
  #8454
Blue Dream's Avatar
I drove ttrank's car solo
Sadly we can't use them on our G. It has the auto-adjusting power wheel with the I-key and that mod only works on the manually adjusted steering wheel.
Old Jun 10, 2018 | 01:17 AM
  #8455
theronz's Avatar
Old Jun 10, 2018 | 01:19 AM
  #8456
theronz's Avatar
Old Jun 10, 2018 | 08:35 AM
  #8457
Blue Dream's Avatar
Sure wish there was a plug and play option for the first gen Gs.
Old Jun 10, 2018 | 10:35 AM
  #8458
Albanian122's Avatar
that looks so beautiful
Old Jun 10, 2018 | 11:12 AM
  #8459
Hall Stevenson's Avatar
"Tail as turn" mod was the first thing I did when I got my car. I wish I could see or enjoy this one more but hopefully the people behind me do !
Old Jun 10, 2018 | 11:29 AM
  #8460
Conissah's Avatar
New aluminum radiator (biggest PITA ever) which fueled me do something fun so I made a "cool air injector" based off the thread somewhere on here.
