G35 & G37, Coupes & Sedans
Old Sep 18, 2017 | 06:20 PM
  #7696
joeb1983's Avatar
G35
Started researching into what all is involved to ensure a functional SRS with aftermarket seats installed on a 2006 G35 coupe.
From what I've read, tricking the system into thinking there are seat airbags installed is pretty straight forward, utilizing 2.2 ohm, 1/2 watt resistors on each seats respected connector. (Plastered all over the web and this site)
The passenger side is where it gets somewhat involved.
After taking a look underneath, there is a passenger occupancy ECU/module mounted to the right inside frame of your OEM passenger seat.
This module receives, from what I can tell, a signal from a pressure transducer that is linked to a pressure sensing mat that resembles a more robust and fancy, interconnected bubble wrap sheet.
This is the system that activates the passenger side airbag(s) and turns on/off the "passenger airbag off" light.
Incorporating this system into the aftermarket passenger seat doesn't seem too complicated.
It is however a different style system than a G37 or 370z.
I can do a more thorough write-up with pictures in a dedicated thread if anyone would like and or if it hasn't been done already.
Let me know.
Anyways, I have to drill the Sparco brackets to the width of the seat rails. (No big deal)
Also, the passenger side seat bracket only comes in one height and its TALL... I can't tilt the seat forward fully to access the back seat as it hits the headliner. (sunroof model, so that doesn't help any) I'm 6' and my hair grazes the headliner in some positions.
Shouldn't be an issue with the driver side as I order the low option.
Old Sep 18, 2017 | 07:36 PM
  #7697
JZ39's Avatar
Yes, please do the write up. Definitely needed. As I mentioned, the Buddy Club low rose seat rails seem to be the option for the lowest position and I believe are adjustable to a number of heights.
Looking forward to your project. This will inspire me to tackle this next spring!
Thanks in advance.
Old Sep 18, 2017 | 07:56 PM
  #7698
joeb1983's Avatar
G35
Thanks in advance.
Will do and no problem.
I believe the BC brackets are designed for side mount buckets if I'm not mistaken; or are people modifying them to run on bottom mounts?
Old Sep 18, 2017 | 09:34 PM
  #7699
JZ39's Avatar
Yes, in checking I think you're right about the fact that they are side mounts.
Old Sep 22, 2017 | 11:49 AM
  #7700
ferrari71298's Avatar
New Springs/Wheels
In the Process of installing my new Eibach lowering springs/ Work Emotion 11r Wheels, Ill have pics when I'm finished later today. Ill be going to street car takeover here in STL this weekend so hopefully ill see more G's and Z's there!
Old Sep 22, 2017 | 04:35 PM
  #7701
Urbanengineer's Avatar
Fabulous ^^^^^^^
Old Sep 26, 2017 | 10:22 PM
  #7702
joeb1983's Avatar
G35
Just spoke with Jose with Ionic Dynamics. Ordered a Gialla style grill and their eyelids painted liquid platinum to match.
If the fitment is like their rear diffuser, there shouldn’t be any problems at all. It was bang on...
The grille should allow more air flow, especially to my aftermarket power steering cooler. (Trans cooler)
Be a little bit of a lead time, but I’ll be sure to post some pics when they come in and once installed.
No headway on the seats, but I got the resistors in as well as some small electronic project boxes.
Old Sep 26, 2017 | 11:26 PM
  #7703
Hell yeah!
Excited for the results.
Old Sep 26, 2017 | 11:29 PM
  #7704
BradMD_96's Avatar
Fitted my replacement (used) sports steering wheel. Old one was all dried and cracked up.
Feels good and now the interior is all in very good condition, it was only the old steering wheel that gave away the mileage.
Old Sep 27, 2017 | 01:21 AM
  #7705
Mine is starting to wear. Very nice. I should look into it.
Old Sep 27, 2017 | 06:53 AM
  #7706
Blue Dream's Avatar
I drove ttrank's car solo
Now if you could replace the metra finisher with a JDM your interior would look amazing. It's too bad Scoshe doesn't make one for 05-07 coupes yet, theirs looks great as well.
Old Sep 27, 2017 | 10:27 AM
  #7707
joeb1983's Avatar
G35
I know exactly what you mean... I’ve been wanting an aftermarket double den for years...
The JDM DD trim is pricey, but it looks so good!
Old Sep 27, 2017 | 11:38 AM
  #7708
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Looks good! What did that cost? My '04 isn't too bad compared to others I've seen, but I wouldn't mind replacing it. Too bad I became lax with my Lexol conditioning.
Old Sep 27, 2017 | 03:02 PM
  #7709
BradMD_96's Avatar
That's the same reason I have the metra unit (bought for $40 used without the harness) and used the OEM dash piece so no need for the metra trim.
I paid $65 shipped for this. A great deal on facebook from one of the g35/350z/etc groups. Prior to seeing this I did see a few on eBay too. There still is one for about $60, it's also a sport wheel but the leather doesn't look as supple in the pictures and the orange stitching is darker from dirt I suppose. I asked for more pics but they didn't send any.
I was thinking about going with a G37 wheel. You can get them reasonably cheap too and the controls can be wired to work but the cost of the airbag is too far a stretch for the budget.
Old Sep 27, 2017 | 05:49 PM
  #7710
JZ39's Avatar
Amazing, except for that 5AT shifter
