G35 & G37, Coupes & Sedans
Old Nov 1, 2017 | 07:25 AM
  #7846
.cakestar's Avatar
where are those ball joints from?
Old Nov 1, 2017 | 11:05 AM
  #7847
Urbanengineer's Avatar
Originally Posted by EPiK
Is that a fan on the back of the light housing?
Yeah he’s a douche who puts HID/LED in a reflector becuz mad white output yo and terrible vision at night. But it’s Mad JDM and the eBay listing said it was an improvement. He’ll be blinding everyone.
Originally Posted by BradMD_96
All back together, 5 hours later.....gonna sleep good tonight.
I could definitely do it in about half that time now though.
Will be testing these for the next couple weeks...
Put halogen back in or retrofit a projector you are blinding other road users. You would fail inspection if your state had one.
Originally Posted by Ren13V35
man, supplying good rubbers for 20Â’s gunna be pricey
It’s actually cheaper than 19â€. 19†seems to be the most expensive.
Get it in a lift, grab the input shaft with both hands and start aggressively pulling it up and down while someone visually inspect the bushing. Rinse/repeat for the sides where the axles are.
Also you can use binders on the front tires on a drive up lift and lightly drive fwd/rev while inspecting the bushings, make sure to bind the front of the vehicle really securely though and leave the drop-stops up
Z1 has a really good video of it on their Diff bushings page, on their website. It’s also on their YouTube channel.
Old Nov 1, 2017 | 11:31 AM
  #7848
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yep just watched the video, excellent presentation and description of what exactly the part is, how it affects the vehicle, and how a suitable upgrade affects performance and longevity.
https://www.z1motorsports.com/z1-pro...t-p-10356.html
Old Nov 1, 2017 | 04:36 PM
  #7849
Edgarc6789's Avatar
My coupe came with hids not halogen from factory does that make me a dushhhheee too?
My 04 g35 came with reflectors and I installed hids I just adjusted them and my 06 as actually more brighter
Old Nov 1, 2017 | 04:38 PM
  #7850
Edgarc6789's Avatar
I'm just going to replace them
Should I go z1 or whitine? What have you guys used ?
Old Nov 1, 2017 | 04:48 PM
  #7851
cleric670's Avatar
BANNED!!!
Honestly they're all good, energy suspension also. I don't know that you would feel a difference between any of them and longevity would likely be the same as well. I like the Z1 because of the pricetag so...
Old Nov 1, 2017 | 05:19 PM
  #7852
Edgarc6789's Avatar
92.71 z1 shipped
95.38 white line ebay
Old Nov 1, 2017 | 05:23 PM
  #7853
cleric670's Avatar
BANNED!!!
You can DM Z1 about their forum vendor price as well, probably not the same as their storefront list price.
Old Nov 1, 2017 | 08:18 PM
  #7854
BradMD_96's Avatar
MAS ball joints, you can get them from Rockauto or eBay. I posted more on the lower ball joint thread.
You're ill-informed if you think the LED headlights in a reflector housing perform like a HID bulb.
This is the light output, it does not scatter nor dazzle oncoming drivers.
Old Nov 1, 2017 | 09:04 PM
  #7855
Edgarc6789's Avatar
When I installed leds in a car they didn't seen as bright as hids
Old Nov 1, 2017 | 09:23 PM
  #7856
BradMD_96's Avatar
While they aren't brighter than ~50W HID kits, they are better than the OEM 03-04 HID's. Also, it depends what sort of bulbs you got. There are many made with cheap/replica led chips which either give poor light output, struggle to order the beam pattern or throttle power usage to reduce temps.
Additionally, they cost far less and are simply plug and play vs mounting/connecting ballasts etc.
Old Nov 1, 2017 | 09:50 PM
  #7857
Edgarc6789's Avatar
It takes me longer to remove the bumper than it does to install the bulb and ballast
The only thing I find good about the leds is that you don't have to worry about the ballast
Old Nov 1, 2017 | 09:56 PM
  #7858
BradMD_96's Avatar
I swapped them in from under the wheel wells. Also, the LED's come on instantly compared to the warmup experienced with HID's.
Old Nov 1, 2017 | 10:01 PM
  #7859
Edgarc6789's Avatar
I have remote start so by the time I get to the car there ready
Old Nov 1, 2017 | 10:59 PM
  #7860
cleric670's Avatar
BANNED!!!
Even in the coldest weather it doesn't take longer than 10 seconds for the lamp to reach temp and the gas to homogenize.
