G35 & G37, Coupes & Sedans
Old Jun 19, 2018 | 09:05 PM
  #8521
Red Shogun's Avatar
Garnet Ember G35X Sport EBC rotors LEDs GTR button Tail-as-Turn TBW undertray Alarm shock sensor
Well I don't track the car and seldom try "excessive displays of speed/launches" so the fix might hold for awhile. If I was auto-crossing the car I would have went with the Whiteline fix.
Motorvate still hasn't posted an update to tell people if it held and it's been 6 months.....
If it doesn't hold, I can still do the Whiteline bushing fix although I'll probably "contract that job out". I've got the tools, I just don't have the will to disconnect everything and drop the diff. while wiggling under the G35 while it's on jack stands. If I had a lift... :-(
Old Jun 20, 2018 | 08:54 AM
  #8522
cswlightning's Avatar
This seems to work the same way in principle to Z1's subframe collar spacers, except in this case the spacers are inserted as a liquid and are epoxy rather than aluminum. Epoxy is very strong under compression (not so much tension) which is the only thing it is being asked to do in this use case. It isn't going to fall out as it's bonded to the cracks and crap inside of the rubber and is larger than the hole you put it into, which shouldn't grow any since the epoxy "spacer" has taken the dynamic stress off the rubber.
Can you please change your driving habits and start drag launching the car everyday? I wanna see if your car holds up under abuse
This gave me an idea: I know I'm never going to install subframe collars on my G since it's my daily and given the state of everything else they're probably blown. It might be fun to try filling my subframe bushings with epoxy to see what happens, nothing really to go wrong so why not?
Old Jun 20, 2018 | 09:55 AM
  #8523
Urbanengineer's Avatar
Interesting idea. Why not just fill them with a solid rubber bushing at that point? There is nothing to hold in the epoxy though, it will likely wiggle out.
Old Jun 20, 2018 | 10:25 AM
  #8524
The Z1 spacers seem to stay in place, I have no doubt that using the adhesive properties of epoxy coupled with some creatively placed materials a similar effect could be devised. I'm thinking now of cutting out a couple thin sections of sheet metal, drill a couple holes in them lining up with the slots in the stock rubber bushings, and putting long screws through the plate so they would be going up through the cavity in the bushings.
I'd insert this plate from underneath the bushing, and fill the cavities with epoxy so the epoxy dries in place around the screws. This would connect the two epoxy "spacer arms" with eachother and provide structure to the assembly. If I really wanted to be sure nothing moved I'd put another one of these assemblies into the top of the bushing after pouring the epoxy.
According to quick google search compressive strength of epoxy starts at about 70 MPa or 10,000 lbs/in^2 which while about 1/4 the strength of aluminum is more than twice that of concrete, so given the weight of the G and the max force these are going to see (accelerating WOT, going over bumps) there's a pretty good margin of safety there for that part. In my (non-expert) opinion it should last permanently.
A solid rubber bushing would be great, but it's not as easy and quick to do as epoxy and you can't really support it once it's been cast. What I'm considering is essentially using the stock bushing as an in-place mold for a Z1 style subframe spacer.... except using epoxy. You could probably use polyurethane for this as well but I don't have any of that lying around and I doubt it would play nicely with the screws and sheet metal idea due to the flexing.
I have never looked at a subframe spacer and have no idea how forces are distributed, so I'd have to take a look at how the forces are distributed before I'd try anything like this. But if it's similar to the diff bushing I can see this working.
Old Jun 20, 2018 | 12:34 PM
  #8525
John Tavarez's Avatar
Today I redid the seats in my 04 coupe. If any of you guys are looking for any car vinyls or headliner and the such I found this website called yourautotrim.com. They also have a 15% off code at check out and free shipping lol
Old Jun 21, 2018 | 12:49 PM
  #8526
Thumbs up g35
I redid my seats and wrapped my dash in vinyl leather. Also if any of you guys are looking, I found this website called yourautotrim.com and they sell all types of vinyls and leather. They have headliner too and a bunch of other stuff, yall should look at it, its helped me a lot.
Old Jun 21, 2018 | 03:01 PM
  #8527
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Got any pics, or are you really here to pimp out your site in multiple threads?
Old Jun 21, 2018 | 03:16 PM
  #8528
Edgarc6789's Avatar
So the z1 inserts arent any good ? I have the whiteline bushings just sitting there... I read the z1 inserts are easier to install
Old Jun 21, 2018 | 03:27 PM
  #8529
Thumbs up
I actually redid my seats, new to the forum so i'll have to figure out how to post pictures. Also, I used their headliner for my F150
Old Jun 21, 2018 | 03:48 PM
  #8530
20 Year Member
Apologies then, but it didn't appear to be that way initially.
Old Jun 21, 2018 | 07:57 PM
  #8531
Blue Dream's Avatar
I drove ttrank's car solo
If it matters I didn't interpret it as John pushing "his" website. I haven't seen any other posts he might have mentioned the site in so no feedback there. Also the forum rules don't prevent people from posting/discussing other websites unless they are a competing G35 site. See here: https://g35driver.com/forums/faq.php?do=search&q=gain
All of us need to be aware that spamming can be a huge problem so I wouldn't recommend pasting a recommendation to a particular website in multiple posts across multiple forums. I think I skirt that rule a bit, I'm always pointing people to Amazon for OEM sensors because they're relatively cheap but it doesn't seem to be an issue with the powers that be. l guess to be safe I'll just PM members that info.
Old Jun 22, 2018 | 09:49 AM
  #8532
Yeah sorry if that came out wrong lol, but I would recommend them for vinyl and headliner
  #8533
20 Year Member
All five of his first posts mentioned the site, that's what set off my alarm.
Old Jun 22, 2018 | 10:54 AM
  #8534
Blue Dream's Avatar
^I sent you a PM this morning...
Old Jun 22, 2018 | 11:35 AM
  #8535
Mine is cracked and torn, I'll consider that! Did you have to remove the dash?
