G35 & G37, Coupes & Sedans
Old Jul 27, 2018 | 12:41 PM
  #8671
eazdaskeez's Avatar
Sooooooo I somehow got a set of bi led projectors from trs for free. Retail is about 480, undecided on selling them or keeping them. Quick mockup shows that they fit in the lower portion of then headlight. Things are massive and even has a fan on the bottom of them. Plus side is no bulbs or anything, it's all built in.
Old Jul 27, 2018 | 07:45 PM
  #8672
Urbanengineer's Avatar
What!? I spend more there than you do .
Figured out that loud exhaust of mine wasn't just the ART pipes... it was an exhaust leak from a small rust crack :facepalm:.
Old Jul 27, 2018 | 07:47 PM
  #8673
The install begins .
Attached Thumbnails What did you do to the G today?-photo312.jpg   What did you do to the G today?-photo345.jpg   What did you do to the G today?-photo34.jpg
Old Jul 27, 2018 | 07:59 PM
  #8674
Edgarc6789's Avatar
I would of thought you would of one of the first people to have the art pipes and Tdx in your car :-0
Old Jul 27, 2018 | 08:08 PM
  #8675
Albanian122's Avatar
would those work with coupe? Like quad projector ?
Old Jul 27, 2018 | 09:50 PM
  #8676
eazdaskeez's Avatar
Anything will work if you don't mind cutting and making it work lol
Old Jul 27, 2018 | 09:54 PM
  #8677
Edgarc6789's Avatar
+ jb weld
Old Jul 28, 2018 | 12:51 AM
  #8678
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Edgar, I'm a little late to the party but the front upper control arms are different on the driver/passenger sides, the ball joint is set slightly to the rear of the geometry. Just because your dust shield is wearing out doesn't mean the ball joint is bad though but it's probably getting close if you have 100k on them.
KYB renamed their shocks a few years back to make things less confusing, the old GR2 is the exact same item as the new Excel-G. Funny thing is everyone remembered GR2 and now it's more confusing for folks who didn't know about the name change >.<
Old Jul 28, 2018 | 01:47 AM
  #8679
Edgarc6789's Avatar
thank you
From everything I read im fetting the shocks and upper arms then
My car is riding rough already so it wouldn't hurt to change these parts of there about to fail
Old Jul 28, 2018 | 04:04 PM
  #8680
Edgarc6789's Avatar
So far I ordered KYB front strut mounts & KYB rear shock mounts $97.19 shipped - Rock Auto
KYB 4 Struts $247.88 - Ebay
hopefully that fixes all the clunking and popping i hear
Old Jul 28, 2018 | 06:29 PM
  #8681
parapraxis24's Avatar
Replaced the rear diff bushings with Z1 Motorsports poly bushings.
Getting them out was a bit of a pain. One of the ear bushings came out with a few good whacks of the hammer and a chisel, the other was a royal pain in the butt. The ear bushings were actually in pretty good shape, they still had all the fluid in them (which we found out). The trick is if the bushing wont budge, find a way to cut the sleeve with a sawzall using thick metal blades. One cut was enough to relive the tension that the teeth on the blade actually pulled what was left out. Same thing with the rear bushing, once we were able to cut the sleeve with the blade, it slid out really easily.
Installation was a breeze. I had the bushings in the freezer for 24 hours, and they literally slid in by hand. Whether or not that was actually needed, I don't know but I'll take it.
Driving impressions: ALL of the slop is gone. Between shifts it would thud audibly but not any more. I would also get a weird vibration during engine braking between 3-2k RPMs, that's gone too. Feels like a new car again, I'm super stoked about it.
If anyone is out there and they think their bushings might be going out (the poop streak over the rear subframe is the giveaway), do this. You might curse a little bit along the way but it's definitely worth it.
Old Jul 28, 2018 | 06:37 PM
  #8682
this excites me I have bought a set of z1 poly bushings I have yet to install them I will try and get them on when I install the subframe bushings too
Old Jul 28, 2018 | 10:50 PM
  #8683
Edgarc6789's Avatar
Had these for around 6 months I never even opened them lol
I want to try the collars instead
Old Jul 29, 2018 | 09:31 AM
  #8684
eazdaskeez's Avatar
Finally figured out why I keep tripping a knock sensor code lol. Guess I'll be cutting and splicing today
Old Jul 30, 2018 | 12:07 PM
  #8685
Lol when in doubt check the hardware ^^
Install is started, need to make minor adjustments because the exhaust is too high and too far in towards the center.
I also figured why my exhaust got uncomfortably loud all of a sudden on the drive back from home a few weeks back. Whoops, that's the Northeast for you.
Attached Thumbnails What did you do to the G today?-photo838.jpg   What did you do to the G today?-photo994.jpg   What did you do to the G today?-photo858.jpg   What did you do to the G today?-photo405.jpg
