G35 & G37, Coupes & Sedans
Old Oct 19, 2018 | 07:07 PM
  #9106
Edgarc6789's Avatar
800,1000,1500 and stopped at 2000 grit
Old Oct 19, 2018 | 08:20 PM
  #9107
Urbanengineer's Avatar
Bruh you just painted that hope it turns out like you want.
Old Oct 19, 2018 | 08:36 PM
  #9108
Edgarc6789's Avatar
Not even lol
I painted it like 6 months ago ? I dont remember
I love those swirl marks left by the wool pad.....
I still need another pass with foam pad with compound
them 2 passes with polish
and maybe a da polisher if those swirls dont come out by then
Old Oct 19, 2018 | 09:59 PM
  #9109
Albanian122's Avatar
this happened today smh
Old Oct 19, 2018 | 10:06 PM
  #9110
Edgarc6789's Avatar
How? 0.0
Old Oct 19, 2018 | 10:14 PM
  #9111
How? 0.0
One side was already hanging lower, from bottoming out a few times... finally gave way
Old Oct 19, 2018 | 11:06 PM
  #9112
Is that a TDX2 that gave way oh ****. .
Old Oct 19, 2018 | 11:17 PM
  #9113
damn TDX , luckily I had new exhaust tips already, hope it’s an easy fix
Old Oct 20, 2018 | 12:33 AM
  #9114
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's just metal, easily welded back together.
Old Oct 20, 2018 | 10:08 AM
  #9115
LoSt180's Avatar
can't weld rust.
Old Oct 20, 2018 | 10:10 AM
  #9116
Edgarc6789's Avatar
Fiberglass it.
Old Oct 20, 2018 | 08:28 PM
  #9117
cswlightning's Avatar
Speaking of rust and fiberglass.... the slow progress continues. Bondo is pretty annoying to work with so I made this mold to get the arch right. After sanding off all the excess it looks pretty good, just one more can and it'll be ready for primer and plastidip until I can get some proper paintwork done.
Old Oct 20, 2018 | 11:53 PM
  #9118
Hall Stevenson's Avatar
Replaced the factory-installed serpentine belt - it lasted 116k miles so far. Didn't break, was just on my list of things to do maintenance-wise. Replaced it with a Gates belt and I've got the OEM belt along with a 3/8" drive ratchet in the trunk "just in case".
I will say, if anyone with an '07-08 does this, I'd suggest removing the engine splash shield on the underside and work on it from the top and bottom. Actually, the FSM says to do this too but I've seen some videos and those folks did it all from above. That's impressive if they did ! Well, one video the guy skips showing the actual routing process.... None of them mention removing the shield though (older models use a bolt-adjusting tensioner and those do require access from below for sure).
Old Oct 21, 2018 | 08:44 PM
  #9119
cleric670's Avatar
BANNED!!!
Wait, newer ones don't use the manually adjusted tensioner???!!! Can the other adjuster be used on the earlier style?
Old Oct 21, 2018 | 10:31 PM
  #9120
'08 models use an automatic belt tensioner and I presume the '07 is the same.
Can the what be what ?
