G35 & G37, Coupes & Sedans
Old Oct 20, 2019 | 08:06 PM
  #9991
LoSt180's Avatar
G got booted from the garage. New lady in the stables.
Old Oct 20, 2019 | 09:16 PM
  #9992
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Wow I love that wierd stagger dual tip setup!
Old Oct 20, 2019 | 09:20 PM
  #9993
Mr. Brooks's Avatar
[QUOTE=LoSt180;7177344]G got booted from the garage. New lady in the stables.
Both rides are sick
Old Oct 21, 2019 | 12:52 PM
  #9994
Urbanengineer's Avatar
That stagger is totally a Lexus signature.
  #9995
With your G approaching 300k miles it's about time it got put out with the dogs on the street :P!
Old Oct 28, 2019 | 01:15 PM
  #9996
Row2k's Avatar
20 Year Member
G35 Coupe
Completed my all carbon front brace and finally installed it. A bit of a shame it will be hidden. Started working on my front splitter again; reworking it for the millionth time for more down-force.
Old Oct 28, 2019 | 03:43 PM
  #9997
Mr. Brooks's Avatar
Nice
Is that a carbon wrap or a true carbon brace. If it's a true carbon brace. How good would a frontal collision be.
Old Oct 28, 2019 | 03:59 PM
  #9998
cleric670's Avatar
BANNED!!!
Hollow core would typically be substantially weaker than aluminum unless it was much thicker to compensate. Foam core would be much stronger than aluminum though, CF can distribute the impact incredibly well if it's foam filled. It's pretty common to find foam filled CF on high end sports cars now as OEM equipment.
Old Oct 28, 2019 | 07:17 PM
  #9999
Very nice. Sad it's hidden. Why not just use OE? Am I missing you will be using a bumper too?
Old Oct 28, 2019 | 09:43 PM
  #10000
Row2k's Avatar
20 Year Member
G35 Coupe
true carbon, not a wrap. Its multiple layers of carbon at various orientations and strand types along with 2 layers of Soric LRC core material separated with a few more layers of carbon for extra thickness where I wanted to add rigidity all forming a nice sandwich ready for infusion. A surprisingly large amount of engineering went into this.
Front crash bar doesn't really do much for you in terms of a frontal collision, it's the two main beams that run along both sides of the engine that form the bulk of the crumple zone.
Pic during some of the early layup steps:
correct, 2 layers of Soric foam core material were used in between the carbon layers. And yes, I got the idea from OEM applications; the e46 m3 and e92 m3 , which both utilize a carbon front crash bar:
e92:
e46:
I wanted to get better at building strong structural carbon fiber parts, so this seemed like a good start for bang for the buck in terms of weight loss and practice. Also my goal is to take off as much weight from the front of the car as possible, so this is a good place to start considering its at the very tip of the car. The new carbon fiber bar weights only 5.2lbs, stock was 12.7lbs. I did my best measurement of torsional rigidity and it seems to be about the same strength as the aluminum, maybe 10% less. However I expect its much better in terms of tensile strength across the two mounting locations since I put in multiple layers of unidirectional fibers running across and really I expect that's where the strength really counts. Sadly I don't have a method to test tensile strength. I haven't had a chance to go driving it yet, but I'll probably do some back to back testing with the aluminum and see if I can tell a difference.
Old Oct 28, 2019 | 10:31 PM
  #10001
Neat. I've been to a couple places that make it and it blows my mind the technology it takes to make it. I'm Jealous and wish I was local to ya to check out how you do it.
Old Oct 29, 2019 | 05:23 AM
  #10002
ScraggleRock's Avatar
Lemme get them sport sides..
Old Oct 29, 2019 | 12:50 PM
  #10003
LoSt180's Avatar
That's pretty rad.
Actually got the boot when my kids started riding their bikes a lot and I got tired of moving things around 🤣.
Most likely going to keep it around as an extra car, maybe give it to my daughter when she turns 16. After putting stock wheels back on it of course.
Old Oct 29, 2019 | 01:44 PM
  #10004
That's pretty rad.Actually got the boot when my kids started riding their bikes a lot and I got tired of moving things around 🤣.Most likely going to keep it around as an extra car, maybe give it to my daughter when she turns 16. After putting stock wheels back on it of course.
You don't want to see those wheels all scraped up? She's gonna be a cool 16 year old !!
Old Oct 29, 2019 | 06:27 PM
  #10005
joeb1983's Avatar
G35
Stopped by my buddies shop and gave the ok to spray.
