G35 & G37, Coupes & Sedans
Old Oct 31, 2013 | 10:47 PM
  #1306
jookyshank's Avatar
I haz hugz to givez
Have some...just in OB...you know how hard it is to get AB body parts!? lol I'm tryin to find a good painter to get em swapped over
Old Oct 31, 2013 | 10:50 PM
  #1307
saywat?'s Avatar
should be easy to match imo.
Old Oct 31, 2013 | 10:51 PM
  #1308
jookyshank's Avatar
I haz hugz to givez
yea, not too hard, but I'm picky
Old Nov 1, 2013 | 07:52 PM
  #1309
JKL1031's Avatar
Ahh, just sell them to meh.
Old Nov 1, 2013 | 08:29 PM
  #1310
jookyshank's Avatar
I haz hugz to givez
Already found a painter I have some front ones I'd sell tho ...
Old Nov 2, 2013 | 11:56 AM
  #1311
Lartytiejdke3's Avatar
Speakin of paint of I finally got around to fixing up some bad paint chips on my front end. Much cleaner now
Old Nov 2, 2013 | 02:00 PM
  #1312
OBsessed's Avatar
Ported NWP Throttle Body, Kinetix Velocity, lower runners and new 3.5" FuRookie intake installed, Osiris tuned. Car feels good. Don't ask for numbers, didn't get a before, haven't dyno'd for an after, feels great and I don't care about dyno numbers on the engine as it currently sits, that'll come a bit later.
Old Nov 2, 2013 | 08:22 PM
  #1313
jookyshank's Avatar
I haz hugz to givez
B...
Is your TB twisted? or just a celly pix illusion? lol
Old Nov 2, 2013 | 09:41 PM
  #1314
OBsessed's Avatar
It is twisted. It's the NWP oversized throttle body, so from the Kinetix is a black thermal spacer, then the NWP silver adapter plate (which bolts in to the manifold through the normal holes, then has an offset group of 4 bolts so the TB can bolt in without hitting the manifold) rotating it slightly for clearance, and then the TB itself.
Old Nov 2, 2013 | 10:02 PM
  #1315
Shawno72's Avatar
Replaced spark plugs and no oil leaks
Old Nov 3, 2013 | 07:41 PM
  #1316
GreySky's Avatar
Akebono BBK parts
Got the Fueled Racing brackets for the Akebono BBK swap the other day and these are !
http://www.fueledracing.com
Old Nov 3, 2013 | 09:22 PM
  #1317
G_zus's Avatar
Fed Bev 5 quarts of Mobil1 5W-30 Full Synthetic oil and replaced her oil filter. Didn't know we had to remove a thousand screws...longest oil change ever.
Old Nov 3, 2013 | 10:11 PM
  #1318
OBsessed's Avatar
Consider replacing the plastic undertray with a metal one from Toolbooth *****, ZSpeed Performance, or Rare JDM (among others, I'm sure - ToolboothWilly happens to be a member/sponsor though). They have panels that drop down for access to the oil plug, it's only 2 bolts. Well worth it!
Old Nov 4, 2013 | 04:55 AM
  #1319
N8Deezy's Avatar
Shimmed and installed gt spec 4 point brace. Removed bumper cleaned and oiled air filters. Bumper back on and ready for later on today.
Old Nov 4, 2013 | 05:56 AM
  #1320
HotRodG35's Avatar
If your trying to maximize NA induction air flow suggest ditching the NWP adapter and modifying the SSV (weld up existing TB fastener holes redrill and tap new holes) for 75mm TB direct bolt on.
TB outlet with NWP adapter is restricted down to 70mm, SSV intake opening is 72.5mm
See my post #1048.
The TB coolant pipes are easily removed by using vise grips and twist out pipes, tap holes and plug with 1/8" NPT plugs for aesthetics.
