G35 & G37, Coupes & Sedans
Old Nov 5, 2013 | 07:02 AM
  #1321
OBsessed's Avatar
I'll go back and check your post later this afternoon as I have to run out now. But you may have missed that I had everything ported, I didn't make a huge mention of it because most people here don't seem to know what that means anymore, lol. Also it's the Velocity and not the SSV but I don't know if that affects any of your math. Either way, with the port work the outlet of the TB is now right at 75mm, the inlet is now up to approximately 78mm, and the adapter, thermal gasket, and Velocity inlet have all been port matched as well to remove the narrowing that was there previously. They flow right from 75 out at the opening of the flange down to the 70ish mm in the neck during the bend. But I can't really do much about that so I'll just hope it's helping air speed rather than hurting volume.
The other reason to keep the adapter there is for the thermal gasket behind it. I'm doing everything I can (to include later coating/wrapping that nice stainless tube) to keep heat down. Under the velocity is a hondata thermal gasket (also port matched) and under the lower runners are the two NWP phenolic gaskets.
Old Nov 5, 2013 | 08:48 AM
  #1322
brazen's Avatar
I didn't do all this today, but over the last 9 months here's what the G has received. Let's hope 2014 is a little less involved. I did everything except for the IPDM, ECU, and APP. You can read up on my other threads for the story behind that excitement. Haha
Replace transmission oil (Redline)
Flush coolant
Flush brake fluid
Flush clutch fluid
Replace differential gear oil (Valvoline)
Replace spark plugs (OEM NGK)
Replace MAF sensor (OEM)
Replace IPDM (OEM)
Replace ECU (OEM)
Replace APP sensor (OEM)
Replace APP sensor harness (OEM)
Replace battery
Replace air filter
Replace cabin filter
Clean throttle body
Clean upper plenum
Clean lower plenum
Install Motordyne 5/16” plenum spacer
Replace knock sensor (OEM)
Replace knock sensor harness (Z1 Motorsports)
Replace front struts and mounts (KYB 350Z)
Replace rear shocks and mounts (KYB 350Z)
Install 350Z revised springs (2006 350Z)
Replace lower control arm bushings (Whiteline)
Replace compression rods (OEM)
Replace upper control arms (OEM)
Replace front and rear sway bar links (Moog)
Replace inner tie rods (Moog)
Replace outer tie rods (Moog)
Replace lower ball joints (eBay)
Install TBW powder coated aluminum under shield
Install Z1 Motorsports stainless steel brake lines
Install R1 Concepts slotted rotors
Install Akebono Ceramic Performance brake pads
Install integrated iPod control adapter
Install Alpine tweeters
Replace driver door lock actuator ($5 fix)
Replace 3rd brake light
Install custom hidden iPod dock
Re-charge A/C
4 wheel alignment
Old Nov 10, 2013 | 07:11 PM
  #1323
dundermifflin99's Avatar
Detailed my '05 coupe..Has 58k miles, looks awesome with Forged wheels.
Thinking of painting rotor hats...hate damn rust...
Old Nov 10, 2013 | 09:50 PM
  #1324
Lartytiejdke3's Avatar
i took this picture...
that is all.
Old Nov 11, 2013 | 10:13 AM
  #1325
Diode Dynamics's Avatar
That's a nice looking photo. Very clean G
Nick C.
Old Nov 12, 2013 | 07:41 AM
  #1326
AshG35x's Avatar
Nick C.
Nice G .
Old Nov 15, 2013 | 12:00 PM
  #1327
Stubie1918's Avatar
^ Looks great man. I want that bumper! That will be the next thing for the G
Old Nov 15, 2013 | 12:05 PM
  #1328
Stubie1918's Avatar
Finally got my fast intentions exhaust from Tony yesterday. Threw it on this morning and I can not describe how good this exhaust sounds. I definitely won't be listening to my radio anymore
Old Nov 15, 2013 | 12:12 PM
  #1329
Have you posted any videos of it yet?
Nick C.
Old Nov 15, 2013 | 12:20 PM
  #1330
Stubie1918's Avatar
Nick C.
No not yet. I will try to get one soon though
Old Nov 15, 2013 | 12:30 PM
  #1331
Sweeeettt!!! Looking forward to it
Nick C.
Old Nov 15, 2013 | 10:13 PM
  #1332
Clean as always Stub!
Old Nov 15, 2013 | 11:42 PM
  #1333
Drew113's Avatar
Ban Hammer Expert
FI exhaust is one of my favorites, my buddy ryan up in Richmond has one and it sounds beastly
Old Nov 20, 2013 | 05:44 PM
  #1334
06-07 tails
Almost as much of a freshen up as 06-07 heads. Lovin 'em
Old Nov 20, 2013 | 05:52 PM
  #1335
Shawno72's Avatar
06-07 tails
Very nice! What kind of trunk lid is that?
