G35 & G37, Coupes & Sedans
Newbie with Oil Consumtion questions
Old Aug 24, 2016 | 06:19 PM
07'G's Avatar
I just bought an 07' G35 Coupe w/AT and a VQ35DE engine.
The car only has 30k miles on it.
Is this car prone to the Oil Consumption issue I've read about?
I noticed I was down a quart after 3k miles.
Thanks
Old Aug 24, 2016 | 09:37 PM
Sam G35S's Avatar
You have oil consumption on a 2007 ���������� i thought they fixed that issue after 06 VQs,my 03 Maxima is going through some oil(but I drive the rings out of it) and it does 1-1,5qts per 5k miles maybe 2 ************************��
Last edited by Blue Dream; Aug 26, 2016 at 04:51 AM. Reason: Any future mention of street racing can/will result in an infraction, got it?
Old Aug 24, 2016 | 10:10 PM
Lartytiejdke3's Avatar
Originally Posted by 07'G
I just bought an 07' G35 Coupe w/AT and a VQ35DE engine. The car only has 30k miles on it. Is this car prone to the Oil Consumption issue I've read about? I noticed I was down a quart after 3k miles. Thanks
yes
Old Aug 24, 2016 | 10:22 PM
Sam G35S's Avatar
yes
Jerseytaylor- Yes as in?
Old Aug 25, 2016 | 05:20 AM
Yes as in the answer to the only question you asked in your post
Old Aug 25, 2016 | 08:24 AM
gary c's Avatar
Infiniti will tell you one quart in 3K miles is normal! With only 30K miles on your clock your G must have had a rough upbringing. Just check your oil level once a week, topping it off when needed!
Gary
Old Aug 25, 2016 | 09:08 AM
LoSt180's Avatar
Thanks
All VQ35DE engines are prone to oil consumption. Whether or not your car actually has it is really luck of the draw. A quart after 3k is a bit high. "Normal" would be around 1/2 after 3k.
Originally Posted by Sam G35S
You have oil consumption on a 2007 ���������� i thought they fixed that issue after 06 VQs,my 03 Maxima is going through some oil(but I drive the rings out of it) and it does 1-1,5qts per 5k miles maybe 2 if I race some TL's on Hwy ��
OP has an 07 COUPE, so still has the same VQ at 03-06. OC issues seem to have been resolved in the 07+ HR & VHR engines.
Old Aug 25, 2016 | 12:21 PM
07'G's Avatar
Thanks for the reply.
One follow up question on oil consumption.
Does it matter if you have a manual or automatic transmission?
Old Aug 25, 2016 | 12:25 PM
Thanks for the reply. One follow up question on oil consumption. Does it matter if you have a manual or automatic transmission?
manual 05-07's have more OC issues however neither manual or automatic for any year were completely perfect
Old Aug 26, 2016 | 04:54 AM
Blue Dream's Avatar
I drove ttrank's car solo
OP please familiarize yourself with the forum rules and always read the headers of each sub-forum. This one said specifically "No car questions" so I'm moving it.
