G35 & G37, Coupes & Sedans
Metal valve stem caps ?
Old Apr 14, 2018 | 09:54 PM
Hall Stevenson's Avatar
The valve stems on my car ('08 G35X) appear to be aluminum or something and a couple of the caps don't really thread on right. I've just been Googling and it appears that only plastic caps or aluminum caps should be used to avoid galvanic corrosion. Is this the case ? I just bought some metal caps from Autozone and thought I should check before I open the package and install them.
Old Apr 14, 2018 | 11:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's news to me but yes two dissimilar metals in contact will cause corrosion on one of them, usually it's a guess as to which one suffers the corrosion.
I just get the plastic ones because metal caps usually get stolen
Old Apr 20, 2018 | 01:32 PM
Urbanengineer's Avatar
Metal if TPMS, plastic if not.
Old Apr 20, 2018 | 03:02 PM
My tires were losing air about every (2) weeks and setting off the TPMS sensor so I ended up at a tire shop to have them check for leaks. They found no leaks but did have to tighten the TPMS 'valves' and hopefully that was the culprit. Anyway, I asked about valve stems and they said they often run into metal caps that get "stuck" on (galvanic corrosion). I bought some plastic caps.... May not look as nice but they're definitely safe.
RunHighPSI
Sep 15, 2005 03:12 PM
silvsurf
G-SQUAD
Aug 11, 2005 02:01 AM
juggernaut
Jul 28, 2005 01:59 PM
shibal_z
Sep 29, 2004 01:31 AM
