G35 & G37, Coupes & Sedans
Spark plugs/coil problem
Old Aug 8, 2021 | 12:59 AM
JayGee's Avatar
G35 sedan
I just changed my plugs and put in the denso tt iridium plugs and my car is running like crap, I had issues pulling out the boot with the plug, I ruined a.couple boots and had to improvise and get a couple off my parts G35 which is 2 years newer and a g35x. Please help?
Old Aug 8, 2021 | 11:39 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
As long as it was from the same motor the boot will work. VQ35DE motors had a replaceable boot, I don't know for sure but I assume the HR motor had replaceable boots as well but I can pretty much guarantee they are not interchangeable.
To prevent the boot from sticking on the plug in the future smear a little dielectric grease on the rubber inside the boot, then they will come off easily in the future.
Those boots must be in 100% perfect condition, no cracking, scorching, etc. Otherwise they will essentially "leak" voltage out to ground against the well tube.
Are you 100% sure you didn't swap the coil pack harnesses? It's VERY VERY easy to make this mistake.
DE motor harness colors, each harness will have a white/blue stripe wire and a black wire. Ignore those ones, here is the color for the third wire.
Cyl 1, yellow/red stripe
Cyl 3, blue/red stripe
Cyl 5, purple/white stripe
Cyl 2, green/red stripe
Cyl 4, grey/no stripe
Cyl 6, grey/red stripe
Old Aug 8, 2021 | 01:10 PM
Scorpi0's Avatar
Probably mixed up the #4 and #6 coil wires. Definitely dont drive the car like that. It will mess up your catalytic converter. Ask me how I know 😁
ShoTheG35xOwner
Mar 29, 2020 12:09 AM
6mt2dmisfire
Mar 22, 2019 12:04 PM
TayeG35
Oct 20, 2017 09:52 AM
jnkx2001
Jun 10, 2016 04:12 AM
Amy24
Oct 7, 2015 05:01 PM
