G35 & G37, Coupes & Sedans
G35x No Start No Crank Brake pedal locked
Old Jan 30, 2023 | 07:36 PM
StevenDeYoung's Avatar
Broken atm
07 g35x Brake pedal locked into place an car won't start stuck cycling through Acc an On but refuses to start iv replaced the battery an the fuse terminal connecting to the battery still same issue iv looked everywhere through the forums to find this issue an no luck any ideas?
Old Jan 31, 2023 | 10:03 AM
telcoman's Avatar
Veteran: Army
Did anything get wet? Check for water damage, Wet/defective IPDM?
Have you followed the troubleshooting steps in the FSM?
Old Jan 31, 2023 | 12:44 PM
Broken atm
No nothings got wet hasn't rained in months was running perfectly fine parked it an it died when I put it into park an brake locked all the way down an won't crank over
Old Jan 31, 2023 | 04:35 PM
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Possibly a shifter problem affecting the interlock? Look at this thread;I know it seems to be a different problem but they might be related.
Old Feb 4, 2023 | 11:24 AM
Broken atm
Hey sorry been working all week haven't had time to take a look at the forum I just went an looked at the thread an then went outside it appears to be all the way forward an in the park position idk what else it can be?
Old Feb 4, 2023 | 03:12 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Replied to your other thread. If you don't have any dash lights you probably blew something in the fusible link.
Old Feb 4, 2023 | 07:05 PM
Broken atm
I replaced the fusible link. If your referring to the fuse able link on the battery iv replaced it already an the battery it's self thinking it was the issue but still same problem, I just ordered the brake controller module be in Monday someone said it could be that hopefully get that done Monday after work I'll keep y'all updated if it works or not I appreciate everyone that's helping!!
VQ35S
Aug 27, 2023 03:45 PM
JaVq35hr
Mar 10, 2022 06:58 AM
Shawn paul
Dec 18, 2020 01:02 PM
Car
Jul 6, 2015 02:06 AM
kring
Aug 26, 2007 12:07 PM
