G35 & G37, Coupes & Sedans
G35 Crankshaft position sensor !!
Old Mar 28, 2023 | 08:59 AM
vq.yangg24's Avatar
Base Manual 2004 Coupe
My G was taking a while to crank up and start at least like 10 seconds so i checked my engine code there was a p0335 code in my G, i thought it was the cranshaft sensor so i went to rockauto bought a hitachi crankshaft to replace the old one, but after i replace it the car only crank but won't start so i went under the car unplugged the wire for the crankshaft, surprisingly it started but it was still taking a while to start, at first i thought the new crankshaft sensor is broken but it didnt make sense to me how it can start without a crankshaft, i just started repairing cars and stuff but i thought if a car doesn't have crankshaft it wouldn't start up at all.
PLS HELP
Old Mar 28, 2023 | 02:07 PM
Urbanengineer's Avatar
Maybe check your wiring to the CK sensor to make sure you didn’t bottom out and damage the wiring. There is also a chance a brand new sensor is bad… surprisingly. So may also be that. Good luck.
Old Mar 30, 2023 | 06:29 PM
vq.yangg24's Avatar
went to bought another crankshaft sensor it did the same thing as the previous new one, so basically they are not bad, all the new crank sensor can’t get the car start but the old one can, and there’s a p0335 code
Old Mar 31, 2023 | 06:00 AM
Scorpi0's Avatar
Hmm. Interesting.
How does the connector look? How about the wiring?
Old Mar 31, 2023 | 09:11 AM
vq.yangg24's Avatar
By looking at the wiring it looks okay, at first i thought it's the wiring too, but the situation was the old sensors starts, and with the connector disconnected it started too,
i went to bought a another crankshaft sensor, both new sesnor won't start only cranks
Old Mar 31, 2023 | 11:05 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably damaged wiring somewhere.
Dwight1994
Jul 26, 2022 09:03 AM
gg35vq
Jan 3, 2022 05:14 PM
rgatchalian
Aug 5, 2021 09:18 PM
rrod0
Dec 6, 2019 03:29 PM
salena1973
May 23, 2018 04:21 PM
