Codes P0335 need help
Old Aug 4, 2021 | 07:09 PM
rgatchalian's Avatar
2005 G35 Sedan
Smile Codes P0335 need help
Hello Guys,
I got issues with my 2005 G35 sedan. Having trouble codes P0335 Crankshaft Position Sensor A Circuit. I replaced with aftermarket Crankshaft position sensors. All 3 sensors replaced. At 1st I replaced just the passenger side. But still have same error code. So I decided to replace all 3 sensors. Driver side, Passenger side and the crank sensor at the bottom at the back of the oil pan. I am having same issues. It starts but it is throwing away a code P0335. Engine starts, but just worried when driving at low speed it engine dies, I have to shift to N to start again. Sometime no start at all but after a few hours engine starts again. I already replaced the wire harness for the passenger side since the harness lock is broken and it is not locking in place so I have to cut the original wire harness on the passenger side and solder a replacement wire harness. I made sure it that the wires are soldered on same way as before. But I thought it was just the wire harness but still did not work.
My question is which sensor P0335 is throwing this error code the passenger side or the one at the bottom. I already replaced all 3 sensors but bought it from Ebay for just $24.91.
Old Aug 4, 2021 | 07:47 PM
Scorpi0's Avatar
Always replace crankshaft and camshaft sensors with Hitachi brand or OEM.
Aftermarket sensors just dont work for these cars.
P0335 is the crankshaft sensor.
Old Aug 5, 2021 | 09:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Crank sensor is the one at the bottom. Just to rule out other possible issues by using aftermarket sensors put the original OEM cam sensors back in.
As Scorpi0 mentioned, these cars don't play nice with aftermarket sensors, Genuine OEM Nissan or Hitachi, Hitachi was the OEM manufacturer for those components.
Santi612
Jul 5, 2021 12:18 PM
Michael heckart
Jul 2, 2021 01:06 PM
Paul7296
Aug 20, 2020 11:29 AM
JamarcusOS
Aug 30, 2019 02:35 PM
salena1973
May 23, 2018 04:21 PM
