G35 & G37, Coupes & Sedans
G35 coupe trans fluid leak
Old May 3, 2024 | 04:43 AM
Totalthrone190's Avatar
G35 coupe
Question G35 coupe trans fluid leak
new account here, been using the site since before ownership of this beautiful ugly masterpiece, she’ll be pretty one day
as the title says it’s recently developed a trans leak, from the front and rear of the engine bay(rear leak might be oil along with trans fluid) toward the front I’m thinking it’s a trans cooler hose leak could it be the same toward the back? It leaks when running and toward the back it drips on the passenger cat. I noticed it on the way to Chicago for work and saw some smoke under the hood and in the middle under the car at a red light.
while I’m here tho I should mention from day one the car has a delay in shifts but always shifts just a half second or so after I engage, is that normal or is the transmission cooked?
previous owner said “infinitis just do that” lol I deep down know it’s a problem
any words of wisdom would be appreciated
Here’s a pic inter the front near the radiator
Another front pic
This pic is near the cat
It’s pretty obviously red
U can see some fluid on the ground here either oil or trans fluid
Here the ol gal is,bit of a sh!*ter
Old May 11, 2024 | 12:09 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Probably just a leaking transmission line, and the delay in shifts is likely caused by low transmission fluid level due to the leaking.
achillesg
Drivetrain
Sep 4, 2013 12:00 PM
ThatOneDude
Jun 10, 2011 05:21 PM
Ruta30
Apr 26, 2011 10:09 PM
soundmike
Apr 3, 2011 08:26 AM
