G35 & G37, Coupes & Sedans
Do I need the 7500 Mile Service?
Old 01-20-2006, 10:31 PM
kalikid's Avatar
I was looking at a mailer that I received from Infiniti. On the sheet it had recommended services that call for 7500 mile minor maintenance. What do they do and is it needed?
Old 01-20-2006, 11:25 PM
speedgeek's Avatar
Should only be an oil change.
Old 01-23-2006, 06:30 PM
AKG35X's Avatar
Inspect Air Cleaner Filter
Inspect Automatic Transmission Fluid Level
Inspect Axles
Inspect Battery and Clean Terminals
Inspect Brake Fluid Level
Inspect Brake Pads and/or Linings, Rotors and/or Drums
Inspect Charging/Starting System
Inspect Drive Axle Boots
Inspect Drive Belt(s)
Inspect Engine Coolant Level
Inspect Exhaust System and Heat Shields
Inspect Function of All Lights
Inspect Horn
Inspect Power Steering Fluid Level
Inspect Radiator Hoses
Inspect Steering Gear and Linkage
Inspect Suspension Ball Joints
Inspect Suspension Components
Inspect Tie Rods/Tie Rod Ends
Inspect Window Washer Fluid Level
Inspect Windshield Wiper Blades
Replace Engine Oil
Replace Engine Oil Filter
Road Test
Rotate Tires
7500 mile service.
Old 01-23-2006, 07:14 PM
Andy2434's Avatar
One word . . . "Oil"
Old 01-23-2006, 07:43 PM
cerr's Avatar
yeah, lot's of 'inspecting' going on there. only usefull thing is to change oil & oil filter as well as rotate tires.
i'm just going out on a limb here ... i bet u can probably 'inspect' the function of ur lights, horn, starting system, etc. on your own.
Old 01-23-2006, 11:15 PM
JEVERYDAY's Avatar
I did... Just to be sure
Old 01-24-2006, 07:33 AM
G35MC's Avatar
not sure how much they charge for 7500 miles service.
Old 01-24-2006, 08:57 AM
Houston G's Avatar
Isn't your the first few basic maintenance free?
Old 01-24-2006, 10:38 AM
Houston G's Avatar
my first 6 schedule maintenance is free for my 06'
Old 01-24-2006, 02:13 PM
P_Diddy's Avatar
not sure what type of G you have, but a lot of that stuff does not apply to coupes, like rotating the tires. Hard to say whether you should do it or not, because if you don't do it and you have a problem in a year, they are going to say 'you didn't do your 7500 service and we could have caught the problem then' and try to screw you later.
Old 01-24-2006, 02:40 PM
Houston G's Avatar
06' G coupe 6MT
I'm having my first maintenance (3 months or 3,750 miles) this Friday. I'll then confirm if there will be any charge. To my knowledge the maintenance and the loaner will be at no charge.
Old 01-31-2006, 07:49 AM
Houston G's Avatar
Confirmed last Friday scheduled maintenance- Free maintenance and requested wheel balance.
The first 6 maintenance is free- I think it may be a promotion on my 06.
Old 01-31-2006, 10:55 AM
lightforce18's Avatar
I didnt do the 3k one and am not doing the 7500 one. They just looking for more ways to get more money from you.
Old 01-31-2006, 11:28 AM
rs2183's Avatar
mmm, skip the 3, 7, and 15, wait till 30.
Old 01-31-2006, 12:19 PM
MrCrazy's Avatar
Originally Posted by kalikid
...is it needed?
Short answer: yes
Long answer: you can do it yourself but keep good records (and follow at least schedule 2 in the maintenance book as a guideline). Your warranty could be jepordized if you don't do at least oil changes every 7500 miles/6 months - that interval is defined in the warranty booklet.
Quick Reply: Do I need the 7500 Mile Service?
