G35 & G37, Coupes & Sedans
homelink
Old Apr 20, 2006 | 12:55 AM
ajumlvr's Avatar
homelink
Just curious is it possible to add a homelink system to the coupe? I guess ( mirror ). Anybody done it? My car was base with no premium package. Thanks!
Old Apr 20, 2006 | 01:27 AM
vjquan's Avatar
Sure it's possible. You just have to purchase a mirror with the homelink and supply power to it if the harness is not already there. The transmitter is inside the mirror itself. However, once you learn the price of these things, you'll probably just end up using the separate garage remote.
Old Apr 20, 2006 | 01:39 AM
savefatkids's Avatar
i have the home link and i jsut use my garage door opener the homelink is almost impossible to program to my garage...
Old Apr 20, 2006 | 08:25 AM
jersey-G's Avatar
^ How are your openers any different from all the rest?
Old Apr 20, 2006 | 10:57 AM
alexchuang's Avatar
ummm my homelink works perfectly... i love the clean feeling i have with it... no clunky garage door openers hitting me in the face anymore when they are clipped to the visor...
unfortunately there is still a visor that hits me in the face when i try to swing it all around ...
believe me guys... getting hit in the face with the visor hurts
Old Apr 20, 2006 | 12:33 PM
SDG35619's Avatar
damn how tall are you?! 10'3"???!
Old Apr 20, 2006 | 12:36 PM
da mayor's Avatar
for garage openers built after 1998 you have to have someone hold a button on the motor of the opener and also person #2 to be inside the car to program the garage button. if you need any help just PM me i'll try to help you. it's a little complicated but at the same time isn't
Old Apr 20, 2006 | 04:17 PM
P_Diddy's Avatar
Here's a Tip: if you use a separate garage remote, put it on the passenger side visor so it doesn't hit you in the face!
If you want to buy the homelink mirror, Gentrex makes it.
Old Apr 20, 2006 | 04:50 PM
rage777's Avatar
My homelink seems to keep "unprogramming" itself. It has happened about 4 times in 2 1/2 years.
BTW, you don't need two people to do the programming. Just put a ladder next to the garage door opener, push the button, climb down, then push the homelink button that is programmed about three times. You have 30 seconds, which is a lot of time.
Old Apr 20, 2006 | 07:02 PM
da mayor's Avatar
did you press the 1st and 3rd button and hold it down to reset it before you make a completion?
Old May 24, 2006 | 04:54 PM
ttrank's Avatar
Grocery getter
I added one to mine. It is not hard at all. There is even a guy on ebay selling the mirror and a harness for ~$150.
Old May 24, 2006 | 10:57 PM
Msedanman's Avatar
O.F. Administrator
Your opener probably has a "rolling code" feature which means you have a 'smart or learn' button on the opener to finalize the procedure.
It's fiddley to do, but stick with it and another pairs of hands helps too.
G/L
C.
Old Aug 17, 2006 | 12:09 AM
hotice007's Avatar
I just got a new Craftsman garage opener with Security+ and my car opener stopped working... i can't program it even with the manual... =/
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
WordUp
Jan 29, 2005 12:35 PM
wickedG35
Feb 22, 2004 04:55 PM
ucanbyteme
Feb 11, 2004 12:45 AM
BlacKnight
May 21, 2003 09:52 PM
