1st Run: 90.38F, Humidity 31%
Max Hp=221.32 Max Tq: 206.50
2nd run: 90.53F Humidity 30%
Max Hp=225.48 Max Tq=208.19
3rd run: 91.35F, Humidity 31%
Max Hp=223.73 Max Tq=208.72
4th run: 91.63F, Humidity 31%
Max Hp=222.94 Max Tq=210.06
Is it me or are those baseline # really low? This was my first time doing a dyno so it was pretty fun but i don't really like the numbers. Are these # about right?
Looks similar to other 5ATs that dyno'ed at the same time as me. Maybe you were a little higher. I'm sure someone with a 5AT can chime in.
What kind of Dyno? Seems about right for a couple of them, low for others.
The only true purpose of a dyno is to see if mods make or take power from your car and you need to use the same dyno and set-up.
are those your #'s with the spacer installed? i hit 217/208 i believe, completely stock. i have the sedan which has different, less aggressive, ecu settings i believe...Originally Posted by richboy
1st Run: 90.38F, Humidity 31%Max Hp=221.32 Max Tq: 206.50
Man I remember my first dynos - I was depressed too...
Then the Mod bug hit and WAMMO!!!!
Those days were over - every 3HP made me happy!
Now if it doesn't do at least 25HP - I don't even think about it.
Rick
Rick
Your dyno numbers are comparable to mine.
https://g35driver.com/forums/showthr...highlight=dyno
and others...
https://g35driver.com/forums/showpos...34&postcount=6
and others...
and others...
and others...
Quote:
Yes spacer was installed. What ever i have in my sig thats what i gotOriginally Posted by absolutg
