Why no "Super Hicas" 4 wheel steering on G's
Old Oct 10, 2003 | 03:31 PM
logical's Avatar
I was wondering how come Infiniti did not employ the "Super Hicas" onto the G's. They were on the 300ZX twin turbos. Pardon my knownledge, is it because it is a over 10 years technology ?
Old Oct 10, 2003 | 03:39 PM
GX9901's Avatar
Re: Why no "Super Hicas" 4 wheel steering on G's
My guess would be either to keep the cost down or the technology isn't all that useful.
Old Oct 10, 2003 | 03:52 PM
Merlin's Avatar
Staff ALUMNI
Worked pretty good for a stock car but as you added power you had to disable, can't remember why though.
Old Oct 10, 2003 | 03:57 PM
RaySur350GT's Avatar
Both....
The balance on the G is excellent. The HICAS system only moves very little, like 1~2 degress if I remember right.
I hated my Super HICAS on my Z, after time some of them go bad and throw you alignment off.
I had to get rid of my HICAS system b/c with drag radials, it makes the car go crazy. Almost slammed into the wall once!
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Aug 21, 2020 | 08:27 PM
Gstylelivin's Avatar
Coupe,6MT
HICAS issue
I got an 06 g35 6MT with HICAS and I’m having the following issue weird rattling causing car to slightly shake while the key switch is positioned “ON” (the one before the car is actually on !) what’s wrong with it ? Can I just pull the fuse and drive it like that is it safe ...
Old Aug 22, 2020 | 03:30 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yes you can pull the fuse, or pull the harness off the RAS actuator at the rear differential. You will have the RAS error code but there's nothing unsafe about disabling the system.
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
