removing dead pedal?
Old Oct 13, 2003 | 05:24 PM
jaxxx's Avatar
I tried removing mine today but had some trouble...
i tried turning the 2 plastic screws counterclockwise but it woudnt come out.. all it did was make this clicking noise...
any advice?
Old Oct 13, 2003 | 05:31 PM
Msedanman's Avatar
O.F. Administrator
Re: removing dead pedal?
You only need to turn the screws 1/4 turn. Then they should pull out.
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Oct 13, 2003 | 06:27 PM
Shader7's Avatar
Correct, 1/4 turn and they *should* come right out, but the don't always cooperate. To help it out, you can pull on the top when turning the screw, then do the same on the bottom, then the top, and it will seesaw out easily. To put it back in, just line up the screws and push, then 1/4 turn.
03.5 Coupe - Black/Willow, 6MT, Premium, Navi, Aero, Sat
Old Oct 13, 2003 | 07:15 PM
gto2050's Avatar
Actually, when I changed the pedals to aluminum on Sat, only one of the screws released. The other one I just pulled straight up. The replacement also does not "screw" on. It just pushes on. Now a question.....why do you want to remove it? You replacing it with aluminum pedals?
Old Oct 13, 2003 | 10:46 PM
jaxxx's Avatar
I adjusted my clutch pedal height......plus im ordering the alum pedals
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
