clutch wear?
Old Oct 18, 2003 | 04:02 AM
nuttyprof's Avatar
clutch wear?
how do you know when your clutch on a 6MT is beginning to wear down? does the engage point get higher or lower...mean closer to the floor or furthur from the floor. anything else i should be looking out for? thanks
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
Old Oct 18, 2003 | 11:13 AM
StudlyMobile's Avatar
Re: clutch wear?
can't answer your question, but i did read that a study was done as to why clutches wear out in the US faster than around the world. the answer.... US drivers didn't push it all the way down as often as they should.
04 6mtC
Old Oct 18, 2003 | 11:59 AM
mellowkyle's Avatar
Re: clutch wear?
Different types of wear cause different types of problems. I think the most common symptom of clutch wear is it engaging higher and higher from the ground. Then there's the infamous inability to push the stick into gear, I think that's caused by no hydrolic fluid. And don't forget about your car slipping out of gear after being engaged. But seriously, if your clutch is going bad you'll know.
Old Oct 18, 2003 | 04:34 PM
mrman_3k's Avatar
Re: clutch wear?
Well considering how high the pickup point is with these 6MTs, I don't know how much higher it can go for pickup.
Old Oct 19, 2003 | 02:24 AM
nuttyprof's Avatar
Re: clutch wear?
well, i always make sure to push it all the way down...i sit pretty close to the steering wheel too. maybe ill just get an aftermarket clutch when mine wears down.
G35S 6MT
Technosquare ECU
6-wire ground kit
Old Oct 19, 2003 | 02:47 AM
wreck's Avatar
Running for his life!!
Re: clutch wear?
The simple answer is that you will feel the clutch slipping.
G35C 6MT / AMG E55
Old Oct 19, 2003 | 05:22 PM
nuttyprof's Avatar
Re: clutch wear?
i think ive read on the forums of the clutch on the G's going out early for some strange reason. or am i confusing the brake pads and rotors?
G35S 6MT
Technosquare ECU
6-wire ground kit
Old Oct 20, 2003 | 02:02 PM
xenon's Avatar
Re: clutch wear?
That sucks, so when my break pad wears out i just cant go out and buy a aftermarket one and just slap it on and go again? I have to change rotors too?
Old Oct 21, 2003 | 09:58 PM
RamboRami's Avatar
G35driver.com Moderator
Re: clutch wear?
no, i disagree with MrElussive's thinking on this one
The brembos are strong yes, but the whole point of 4 piston brakes is to even-out the pressure onto the rotor, meaning, it will wear EVENLY unlike standard floating piston brakes.
So, when it comes time to change your pads, i am 99% sure that you will NOT have to change your rotors as they are large and thick and will wear evenly.
G35c 6MT DG/Willow/HyperGround/BorlaExhaust
Old Oct 21, 2003 | 10:00 PM
RamboRami's Avatar
Re: clutch wear?
you'll know when its wearing out when you feel the clutch slipping, especially on steep inclines
Old Oct 21, 2003 | 11:25 PM
nuttyprof's Avatar
Re: clutch wear?
thanks guys, this post was a great help.
G35S 6MT
Technosquare ECU
6-wire ground kit
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
AL8782
Oct 3, 2015 10:26 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
Jeff T
Sep 30, 2015 02:00 PM
