Brembro rotor upgrade
Old Sep 11, 2006 | 01:13 PM
jl4punch2's Avatar
my back two rotors need to be replaced so I was thinking of replacing them with bigger drilled/slotted rotors instead of the factory brembro rotor. I would also replace the front two as well. Can I upgrade the rotors to a bigger brembro rotor if I have the brembro package. Thanks
Old Sep 11, 2006 | 02:41 PM
g35rcr's Avatar
you have to change some hardware to relocate the caliper
Old Sep 11, 2006 | 03:46 PM
Nismo G's Avatar
First off its brembo not brembro.....
Also, you cant take the rear rotor and make it bigger...the caliper wont fit on it if its bigger than the one thats on there, but brembo does make upgraded rotors that are cross drilled. If you get the upgraded rotors it will just help with moving heat away from the caliper and rotor...allowing more stopping power.
So yes you can upgrade them, but you cant put a bigger rotor on. It will be the same size as the factory one just more high performance.
Old Sep 11, 2006 | 05:13 PM
GReddySetGO's Avatar
I use Brembo slotted rotors, OE size.
Old Nov 2, 2006 | 10:13 AM
Dan_K's Avatar
How can you tell when you need to replace your rotors? Is there a minimum width?
Old Nov 2, 2006 | 11:02 AM
g35rcr's Avatar
yeah there is a min width, but your rears will not wear out before your fronts
Old Nov 2, 2006 | 11:11 AM
Dan_K's Avatar
Is it listed somewhere on the rotor? Can someone tell me what it is for the stock Brembo brakes?
Old Nov 2, 2006 | 11:58 AM
Yes, it should be stamped on the inside or on the lip of the rotor. I don't remember exactly, I wanna guess something like 26mm or so. But I can't say for sure.
Old Nov 2, 2006 | 12:07 PM
TheKnite's Avatar
I always thought you don't need to change rotors until they warp and vibrate or visualy look abnormal after you resurface them a few times.
Old Nov 2, 2006 | 12:38 PM
When they warp, you resurface them. If they are still above the minimum thickness, you do not need to buy new ones.
Old Dec 18, 2006 | 05:12 AM
traian's Avatar
I was told (by the dealer) that the minimum width is 28mm for the front Brembo rotors and I was quoted $510 per Brembo rotor.
Old Dec 18, 2006 | 06:24 AM
in2win's Avatar
wow$510 EACH , I have the hookup on genuine brembo rotors that are cross drilled by another reputable company. Basicaly getting cross drilled brembos for a fraction of the cost, about $300 front and rear. pm me if needed...
Old Dec 18, 2006 | 10:20 AM
GreenGoblin's Avatar
The goblin resurrection
wow that dealer was trying to but a hurtin on you
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
