Well I am debating about what suspension to get for my 04 G. I know Tein gets a lot of respect and but I would like to know what you guys think as far as the others go and what type of crazy combinations (ie shocks and springs) you think suit your driving needs. I've had Tein on previous vehicles and I've also had the Apexi N1 setup. So far I am looking at doing the Tein Flex suspension with the Hotchkis sways and toe links and some type of camber kit.
For the money Tein is hard to beat. If you are just getting springs then most of the big boys are fine. If going for a full suspension then I would try to stick with one or two brands.
Brian
Hi-Tech,
You know I don't know much about this sorta stuff, but this post might be helpful for you...
https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
Good luck!
Good luck!
For a streetable, yet capable for some track use. HKS.
Pick anything you want, just do your homework though.
